Skipping middle chainring
Results 1 to 9 of 9
    Nov 2002
    Changed my chain and now it skips on the middle chainring. Can I change the clock position of the chainring so the high force position of the chain is on the less worn teeth? It's a Deore M590 crank with friction shifting on the front derailleur.
    Feb 2002
    I'm not specifically familiar with that crank/chain ring but you can almost assuredly determine whether the ring can be rotated just by looking closely at it. If all of the chain ring bolts are the same and each of the mounts on the ring are the same, then the ring can be rotated. Whether this will be of help in any way is another question. I suspect if you look at the worn teeth on the ring you will see the wear is pretty uniform around its circumference.
    Russian Troll Farmer
    Sep 2016
    Yeah, you can try that, but I just don't see this doing anything. From what I understand of the physics behind the whole 'shifting ramps' theory, I don't see where rotational position relative to the next ring would matter much. What WOULD matter are things like a worn chain, worn rings, dirty chain, over-width chain, bent ring, etc.
    "L'enfer, c'est les autres"
    'brifter' is f'ing stupid
    I'd replace the chainring for sure.
    #promechaniclife
    Nov 2002
    Yeah, I did (I had a spare), but had to remove the crank to do it and it would have been easier to just reclock the chainring (I verified it could be rotated). Since I'm using friction shift, I don't think having those shifting pins line up would make a lot of difference in shifting quality. Oh well, just wondering if anyone has tried this with any success. All the teeth look about the same, but I can't see any significant wear either.
    gazing from the shadows
    Jan 2003
    Since I'm using friction shift, I don't think having those shifting pins line up would make a lot of difference in shifting quality..
    The pins and ramps do help with friction shifting. Especially under power. If you think about how pushing a chain sideways into a flat ring is different from one with pins and ramps, I am sure you can see why.
    New chain skipping on old rings is the CLASSIC sign of worn rings. Whether you personally could see the wear or not.
    Sep 2011
    Replace the chainring. Done.
    Feb 2002
    Again, I'm not specifically familiar with this crankset, but are you sure you needed to remove the crank to change rings? I've heard people say that over the years but I've always been able to take the rings off without removing the crank.
    Nov 2002
    Yes, tried that and have done that on other cranks. The outer ring was removable without removing the crank, but I couldn't slip the middle ring out.
  1. Cassette skipping, middle gears only
    By trunkz22 in forum Components, Wrenching
    Last Post: 07-16-2010, 05:18 PM
  2. Romoving Middle Chainring
    By daniell in forum Components, Wrenching
    Last Post: 03-21-2010, 02:30 PM
  3. Shimano 105 42t middle chainring ?
    By csiress2 in forum Components, Wrenching
    Last Post: 08-31-2009, 04:08 AM
  4. Ultegra 6603 triple crank SG middle chainring issues
    By bullseyehubrider in forum Components, Wrenching
    Last Post: 08-18-2008, 05:41 AM
  5. Two chainring questions: D.I.Y. chainring bolt tool; grease?
    By RedRex in forum Components, Wrenching
    Last Post: 06-05-2007, 03:45 PM
