Skips on rear cassette
Results 1 to 5 of 5
    Jun 2005
    I was riding today, and I had 2 skips on the rear cassette. The first was near the beginning of the ride, and the second was around 18mi later. When I say "skip" I mean that I press down on the pedal, and it feels like the chain jumps or slips. It doesn't change gears, it just slips forward. I've had one or two skips on the last few rides.
    The chain and cassette are clean. I lubed them with RockNRoll Gold before today's ride. Each have approx 600 mi, so I don't think it's excessive wear. The drivetrain is Ultegra R8070. The bike is a giant TCR Pro. I know that the chainstay is 5mm shorter than what Shimano recommends. Could this cause the problem?
    I measured the chain according to Shimano's directions, but do skips indicate that the chain might be too short? Or too long?
    Thank you.
    'brifter' is f'ing stupid
    Chain 'length' has nothing to do w/ skipping as you're describing. If the chain/cassette are new it's either:
    Not the cassette, but the chainring.
    Derailleur improperly adjusted.
    Derailleur hanger not aligned.
    #promechaniclife
    Reputation: ogre's Avatar
    Dec 2005
    Stiff link in the chain? I would think that it would show up sooner than 600 miles. Be sure to check the quicklink/connecting pin too.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    If CX's advice checks out is it possible that the freehub pawls are dirty or sticking and the freehub is slipping for a bit before it catches? Only ask because I had a similar issue once with a lower grade hub.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Sep 2011
    Quote Originally Posted by ogre View Post
    Yeah, based on the infrequency of the "skip", this is the first thing I would check. Put it in small/small and pedal backward, watching the pulleys closely to see if the chain skips at one point in the rotation.
  1. SRAM 5.0 Rear Derailleur skips once. Why?
    By Whodat in forum Components, Wrenching
    Last Post: 10-06-2012, 07:19 PM
  2. Chain skips in small cog
    By Argentius in forum Components, Wrenching
    Last Post: 04-11-2007, 03:31 PM
  3. Vino skips the Classics...
    By Under ACrookedSky in forum Pro Cycling - Tour de France
    Last Post: 12-15-2005, 07:39 PM
  4. chain skips
    By timeyer in forum Components, Wrenching
    Last Post: 05-25-2005, 12:10 PM
  5. New DA chain skips
    By siclmn in forum Components, Wrenching
    Last Post: 11-15-2004, 08:48 AM
