Slight cracked stem
Results 1 to 9 of 9
    Apr 2017
    Slight cracked stem
    Long story short found a good deal on a stem that I wanted and that would fit me better than my Zipp sprint 110mm and 12deg drop.
    Problem is I noticed there was what seems like some stress cracking or something near the bolts. Seller said he didn’t know and said I could send it back for refund if I wanted. I bolted it on tq’d to spec and no issues jerked on it and put all my weight on the bars clipped in and seemed to hold up fine....I’m about 200lbs. Thoughts? Should I be fine?
    Jul 2002
    Send it back. There is no such thing as a "slight crack" in a high stress area of an alloy component that is critical for safety. IT shouldn't even be a question.
    Better yet, saw it in half before you send it back so that the clown who sold to you can't sell it again.
    em, PE
    Russian Troll Farmer
    Sep 2016
    OK, since you have 40 posts, I assume this isn't a troll post. Yes, the stem is garbage. If you like the idea of keeping your front teeth, do not use it!
    "L'enfer, c'est les autres"
    Apr 2017
    Ive contacted the seller and said I want to send it back to him. Guess I’ll fork out an additional 100 for a new one.
    Oct 2013
    I don't see any cracks, am I missing something?
    NM.... I see them now down inside the mating surfaces.
    BANNED
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I'm surprised you even need to ask this question. A crack is a crack.
    It may be a good deal for your dentist, not a good deal for you.
    Reputation: burgrat's Avatar
    Nov 2005
    Yeah, it's hard to see but definitely a problem. Don't ride it!
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Hard to see in the photo because of the carbon pattern. But it's irrelevant. If you think there is a crack, nothing else matters. Cracks, especially in stress areas get bigger and fail.
    The seller is even offering a refund. It's a no brainer.
    Apr 2017
    Got the refund and got a new speed stem on the way! Anyone interested in a 110mm sprint stem lmk!
  1. Replies: 12
    Last Post: 01-24-2007, 07:14 PM
  2. slight pain (discomfort) in upper part of the right calf
    By acid_rider in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-09-2007, 06:39 PM
  3. Just finished Tour De Sewer *Slight Rant*
    By c0braje7 in forum General Cycling Discussion
    Last Post: 04-08-2006, 05:52 PM
  4. There seems to have been a slight problem with the database.
    By 6was9 in forum SiteFeedback/Issues
    Last Post: 09-06-2005, 12:44 PM
  5. High Cadence and Slight Downhills
    By Fez in forum General Cycling Discussion
    Last Post: 06-11-2004, 12:14 PM
