Spacer or no?
Results 1 to 10 of 10
Thread: Spacer or no?
    What the what???
    Jul 2009
    Spacer or no?
    SRAM PG1130 cassette 11-36 11 speed
    Shimano 105 road hub 10/11 speed
    The cassette (without a spacer) has a very slight bit of play (outboard/inboard) even when the lock ring is torqued to spec. I'm not sure if this is acceptable tolerance or not.
    The cassette (with a spacer) does not want to allow the lock ring to engage.
    The SRAM site states:
    "cassette fits 10 and 11-speed non-XD driver bodies (1.85mm spacer is required for 11-speed drivers"
    The Shimano hub is spec'd as 10/11.
    Spacer or no?
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    'brifter' is f'ing stupid
    Should not need a spacer. The only time you'd need a spacer is a 10 speed cassette on an 11 speed freehub. The italicized bit you posted is weird. You should only see that on instructions for a 10 speed cassette. You sure it's not just a tiny bit of play in the freehub?
    #promechaniclife
    What the what???
    Jul 2009
    Could be, but it doesn't feel like the freehub. It feels like the cassette itself is able to wiggle just a bit. Maybe I need to recheck the torque. The SRAM lock rings calls for 40Nm.
    The site I pulled the quote from is: https://www.sram.com/en/sram/models/cs-pg-1130-a1.
    Quote Originally Posted by Opus51569 View Post
    Not that this answers your question but what the site says is: "11-42t cassette fits 10 and 11-speed non-XD driver bodies (1.85mm spacer is required for 11-speed drivers"
    So that's not about your cassette.
    And not that it should have anything to do with fitting on a hub but there's this about your cassette: "11-36t and 11-42t cassettes are compatible with 1x drivetrains only"
    Anyway, there is more than 1.85mm of threads on a lock ring. So it wouldn't make sense that a 1.85 spacer is the difference between play and not engaging.
    Have you used either as part of another combo? If you're not messing anything up I can only guess one is defective.
    What the what???
    Jul 2009
    Thanks, Jay. In this case, I am running it as a 1X with a Rotor Aldhu crank and Q-Ring up front.
    Sent from my iPad using Tapatalk
    I'm stumped. Maybe Srams website should have mentioned 11-36 along with 11-42 with regard to spacers? 36 is pretty big and they mention them together with regard to 1x so they may have messed up there I guess?
    But that wouldn't explain your issue. Just doesn't make sense that 1.85 brings you from play to no engagement.
    What the what???
    Jul 2009
    True. Ill keep trying to fix it until I well and truly break it.
    Feb 2002
    Once the lock ring is fully engaged with the cassette (well before your each full torque) any play would be removed. It is much more likely to be as CX suggests - play in the freehub. When you say it doesn't "feel" like that, what do you mean? You should be able to look at where the freehub interfaces with the hub and see if there is any play there when you wiggle the cassette.
    Oct 2011
    Thread the lock ring on till bottoms out without a cassette. Counting # of turns it takes. Mount cassette, do the same till tight. You will now know if the lock ring is bearing against cassetee or bottomed out
    Viola! Mo guess work involved.
    Happy Thanksgiving
    Banned forever.....or not
    Aug 2002
    If the little bit of play bothers you, you might want to try one of the old 1mm Shimano spacers that Shimano supplied with it's 10 speed cassettes.
    Dogbert.
    I>U
  1. I Found Myself Laughingly Saying, "NO NO NO NO"
    By Akirasho in forum The Lounge
    Last Post: 09-27-2018, 05:48 AM
  2. Cassette and freehub spacer-no spacer
    By Opus51569 in forum Components, Wrenching
    Last Post: 08-02-2017, 12:07 PM
  3. Spacer between "Cone spacer" and stem.
    By jhowmah in forum Beginner's Corner
    Last Post: 09-23-2013, 10:43 PM
  4. No dancing, no singing, no clapping, no praying...
    By TerminatorX91 in forum Politics Only
    Last Post: 07-29-2011, 07:59 AM
  5. AC 350 shimano cassette spacer-yes or no
    By Shane in forum Components, Wrenching
    Last Post: 08-04-2004, 11:43 PM
