SPD release got stiffer during a ride
Results 1 to 14 of 14
    ( ͡ ͜ʖ ͡)
    Reputation: old_fuji's Avatar
    Mar 2009
    Yeah, what's up with that? It felt like my 10+ year old SPD's got tighter and tighter every time I stopped and put a foot down on my last ride. Is this a known issue that I've somehow overlooked?
    I lost my phone number. Can I have yours?
    Nov 2002
    Quote Originally Posted by old_fuji View Post
    Are your cleats worn? Have you tried to lube the interface between the cleat and the pedal jaws?
    'brifter' is f'ing stupid
    Don't put your foot down on glue.
    #promechaniclife
    Banned forever.....or not
    Aug 2002
    Do you mean that it got harder and harder to get your foot out of the pedal????
    Maybe your cleat retention bolts loosened up, so that the cleat twisted when you tried to twist out.
    Dogbert.
    I>U
    ( ͡ ͜ʖ ͡)
    Mar 2009
    The cleats are brand new, from when I bought the shoes a couple years ago (I don't ride much, so they're not terribly warn). I haven't tried lube yet, I wasn't sure if oil would draw dirt in and wear the mechanism more than normal.
    Quote Originally Posted by MR_GRUMPY View Post
    I've had that happen with my old shoes; this didn't feel like it. This felt, honestly, most like a brand new set of pedals before you break 'em in, but it only started happening on the last 5 miles of our ride over the weekend.
    Aug 2017
    Something similar happened to me a couple of times. Once, it was a little mud packed into the cleat. My theory is it was from my driveway and dried/hardened over the course of the ride. Another time it was the same story but with slush. I'm assuming slush is mostly a non-issue this time of year, but same concept. Mine were Keo pedals. Once I cleaned the foreign material out of the cleats they worked ok again.
    Nov 2002
    Lube makes a big difference. A drop of oil at the front and back of the cleat, or on the jaws of the pedal where the cleat engages is what you should do.
    As already mentioned, maybe your cleat is loose.
    Inspect your cleats. Probably a burr cause by stepping on something. Just file it off if that's the case.
    Or some chewing gum or who knows what.
    Pedals don't tighten up during rides.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Pedal can feel like it tightened if you hurt your ankle and didn't realize it...
    I feel like my SPDs all need occasional lube and tension adjustment, just the way the world turns.
    Never Give Up!
    Mar 2009
    I once has a very small pebble... and mean very small but enough to lodge into the jaw of the pedal. The only thing I could think of, I must of picked it up when putting my foot down at a stop light. It attached it self to my cleat and when I clipped in, it came loose from cleat and lodged into the pedal... I-dun-know.
    But at the next stop it was very hard to clip-out/swing my foot out from the pedal. Rode the rest of my ride clipping-out with the other foot. When I got home I removed the pedal played around with it until found the pebble. Removed it with a small flat-head screwdriver, everything was back to normal.
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by jetdog9 View Post
    Really? I have never had to adjust my SPD pedals in thousands of miles.
    I vote for a foreign object or a burr.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Reputation: velodog's Avatar
    Sep 2007
    You've gotten older and your age is starting to show itself in your ability to do things that used to be easy. This loss of abilities is happening in a greatly accelerated manor and it ain't gonna get any easier.
    Sorry to be the one to break the news.
    Too old to ride plastic
    ( ͡ ͜ʖ ͡)
    Mar 2009
    I'll get down there and take a peek.
    Sure beats the alternative! If I stop getting older, something's gone terribly wrong.
    Sep 2007
    Yeah, nobody wants to get old but they don't want dirt thrown in their face either.
    Old and grey is my choice, actually old, grey, able and active.
  1. Multi-Release Cleats vs Non Multi-Release Cleats
    By daniell in forum General Cycling Discussion
    Last Post: 07-19-2010, 02:54 PM
  2. Lateral Release Cleats vs. Multi-Directional Release
    By RoadHazard in forum Beginner's Corner
    Last Post: 09-04-2009, 11:44 PM
  3. stiffer frame/less stiff wheels OR less stiff frame/stiffer wheels
    By twelvepercent in forum Bikes, Frames and Forks
    Last Post: 01-08-2009, 10:01 AM
  4. quick release not holding during sprint
    By ibissteel in forum Campagnolo
    Last Post: 05-10-2008, 11:33 PM
  5. Ride, ride, ride, ride, ride, ride and of course ride some more.
    By MB1 in forum Commuting, Touring and Ride Reports
    Last Post: 08-09-2006, 07:05 AM
