squealing rear brakes
Results 1 to 4 of 4
    Unhappy squealing rear brakes
    can you help, i cleaned by bike and now have a terrible squeal from the rear brake, tried cleaning the wheel surface and pads, but need help on what to use etc
    can you help me?
    thanks
    Feb 2002
    Standard fix
    Are the brake pads toed in? IOW, does the front of the pad touch the rim about 1mm before the rear of the pad? This is the standard fix for brake squeal. Another thing to consider would be roughening the pad surface with a little sandpaper. Likewise the rim surface (use 200+ grit on the rim).
    Wink
    Quote Originally Posted by Kerry Irons
    thanks
    Jul 2002
    To toe the pads, use thin cardboard or card stock at the rear of the pad. An easy way to accomplish this is to take two match books (or similiar same thickness material) and place them at the trailing end of the brake pads. Squeeze your brake lever tight (or have someonelse do it for you, or use the velcro attatchment of a glove...). Then loosen and retighten the brake pads on both sides. Check to brake pad alignment to make certain that the pad did not move vertically. Brake pads have been toed in.
    I don't give a damn for a man who can spell a word only one way.
    Mark Twain
  1. rear brakes for this frame?
    By LC in forum Components, Wrenching
    Last Post: 10-14-2004, 11:19 AM
  2. dual pivot brakes....how to release?
    By dpar in forum Components, Wrenching
    Last Post: 09-18-2004, 04:47 AM
  3. Replies: 6
    Last Post: 08-10-2004, 11:32 AM
  4. Road Disc brakes anyone...
    By Stockholm in forum General Cycling Discussion
    Last Post: 05-11-2004, 07:42 PM
  5. Squealing canti brakes
    By winstonc in forum Components, Wrenching
    Last Post: 02-26-2004, 06:17 AM
