• 03-20-2019
    MaxKatt
    Squeeky downshift on cassette
    Guys... I have zero mechanical ability. Before I visit my shop...
    My Fat Bike was perfect when I parked it in the garage for the winter.
    Dusted it off, pumped tires, took a short ride up/down street, tested brakes, ran it through all the gears, etc.
    Everything seems fine except when I down shift on the rear cassette. That one action seems to cause a squeak in the cable as I shift. No squeak shifting up in the rear, no squeak shifting up or down on the front.
    Can anyone guesstimate and tell me if this is something I can address myself? I do have lubricants if this is something I can remedy with that.
  • 03-20-2019
    202cycle
    Something needs lube. follow the sound and apply lube.
  • 03-20-2019
    tlg
    Lube your chain.
    Lube the BB cable guide.
    If neither of those fix it, check your derailleur pulleys.
  • 03-20-2019
    cxwrench
    This really screams bottom bracket cable guide.
  • 03-20-2019
    dir-t
    Quote:
    That's my guess too. But why in the world did you park the fat bike for winter? Isn't that what they're for?
  • 03-20-2019
    MaxKatt
    Quote:
    Indeed, indeed. Fair point. I moved into a new house in late November, so it's been all packing, unpacking, and settling in thru the Fall and Winter seasons. Finally scheduling in some fun. Missed skiing, ice skating, and snow shoeing as well. Such is life.
    I will check that bottom bracket cable guide. Odd that it only squeaks in one direction though?
    Will report back with findings.
  • 03-20-2019
    cxwrench
    Not at all...it squeaks when you put tension on the cable to downshift, it doesn't when the cable goes slack to upshift.
  • 03-21-2019
    dir-t
    Say no more. I hope to never do it again.
  • 04-04-2019
    MaxKatt
    To follow-up on this... forgot to do anything about it before the next ride.
    Ducked into a shop on my route and had the guy look at it. He noted the same thing I did, but highlighted the squeak seemed to be emanating from the center of the cable where it goes from the handle bars down. We tested. I listened and agreed that seemed to be where it was coming from.
    He said there was nothing he could do on the fly, and that I should have someone pull the whole cable and lube it.
    To be continued.
  • 04-04-2019
    cxwrench
    To be continued.
    Replace the cable AND housing.
