SR 11 speed rear derailleur upper pivot rebuild
Results 1 to 2 of 2
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    I made the mistake of buying a used 11 spd Campy SR RD, found out it was definitely hit, so I've managed to rebuild everything on it, but now there is still excessive play on the top (hanger) pivot. Has anyone opened this top pivot? On the diagram it says "Service Center only" and it doesn't have a nice clip like the 10 speed ones have to take it apart. Looking at it it seems there are two different size torx bolts holding it together, any hints/guide to taking them apart? Also on the diagram there appear to be washers or shims on the part labeled RD-SR006, can I mitigate the play with these?
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Matnlely Dregaend
    Jul 2006
    Well turns out those shim looking things are actually gaskets, but still looking for advice on how to reduce the play at the pivot.
  1. Centaur 12-30 with 11 speed C/R/SR rear derailleur?
    By calrider61 in forum Campagnolo
    Last Post: 09-20-2013, 09:44 AM
  2. pivot spring position in Super Record 11 rear derailleur
    By SirVelo' in forum Components, Wrenching
    Last Post: 06-25-2013, 06:16 PM
  3. Spring tension on 11sp derailleur upper pivot
    By tom_h in forum Campagnolo
    Last Post: 06-11-2012, 05:11 PM
  4. Replies: 0
    Last Post: 10-30-2011, 11:39 AM
  5. Single pivot to dual pivot?
    By Alkan in forum Components, Wrenching
    Last Post: 09-05-2011, 09:56 AM
