Sram 1:1 derailer with Shimano bar-end shifter?
Results 1 to 3 of 3
    Dec 2001
    Would a Sram 1:1 derailer work with a shimano bar-end shifter? Does the shifter have enough cable pull capacity?
    Thanks!
    --timfire
    Chicago
    Jun 2005
    Derailleur travel/cable travel ratio
    Quote Originally Posted by timfire
    Since SRAM boasts that the 1:1 travel ratio of their derailleurs is much better than the 2:1 travel ratio of Shimano derailleurs, I'm guessing not.
    Aug 2005
    I don't have any experience with their product, but Jtek's Shiftmate will allow mixing of SRAM and Shimano (or Campy for that matter)
    http://jtekengineering.com/shiftmate_straight.htm
    Edit: I didn't see a model that would do 1:1 SRAM with Shimano shifter...just Campy. I guess you might be out of luck.
