Sram 10 speed cassette a bit wobbly on new Shimano Wheels? (RS80)
Results 1 to 7 of 7
    Jun 2009
    This may not be a a problem at all, but I am curious. I have a SRAM 10 Speed cassette (1070) on a new set of Shimano RS80 Wheels. Cassette slides on fine, but it feels awfully loose. It seems fine after tightening the cassette, but should there really be any play at all before tightening? On my other wheelsets, SRAM cassettes fit snug before tightening.
    Menace to Society
    May 2009
    As long as it's tight when you crank it down it shouldn't be any problem
    Originally Posted by chrdur
    the fact remains that you are talking about a niche sport within a niche sport .
    Jul 2008
    I had a similar problem with my Easton wheels. The Shimano 10 speed cassette body has deeper splines equaling less contact with the cassette. Switched it out for a SRAM/Shimano 9-speed body and all is great.
    “It is just a ‘Game Boy’ that has a gigolo attached at the end telling the racer when to take a piss,” Hinault
    Jun 2009
    split pattern looks a bit different. rather than having fat splines, that use two thin lines per spline... perhaps its a slight weight reduction trick????/
    Nov 2009
    with easton wheels you should either order the sram hub body or go with a shimano cassette cuz the fit is way off if you just shove a sram cassette on em. Splines are very different.
    Jan 2009
    It's easy to be sure. In the same way as the stem has to extend beyond the steerer fot the top cap to work on threadless headsets, the cassette must overhang the cassette body so the cassette compresses the cassette and doesn't bottom out against the body.
    If you remove the lockring, you'll know for sure at a glance.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Banned forever.....or not
    Aug 2002
    If you don't like it, throw on a 1 mm spacer that Shimano recommends when you install a 10 speed cassette on an 8 or 9 speed wheel.
    Dogbert.
    I>U
