SRAM DUB cranks and Italian threaded BB
Results 1 to 2 of 2
    Sep 2014
    I have a new bike on the way with an Italian bottom bracket. It will have Shimano Ultegra Di2. I'm considering replacing the crank with a Quark DUB crank based power meter as I have an older Quark PM on my current bike (SRAM 10sd).
    The issue I have is that apparently SRAM doesn't have an Italian threaded DUB BB. Their Tech Service FAQ says:
    "There is not [an Italian threaded DUB bottom bracket]. 70mm Italian threaded BBs need to use the GXP Italian bottom bracket and GXP spindle variant of the new RED crankset."
    The only Shimano compatible Quark power meters with the correct crank length are the DUB 2-piece models. I can't find any of the older models in the correct arm length. And I haven't found any of the GXP Red cranks arms that work with the Quark DUB spiders.
    So has anyone else run into this or have seen adapters for DUB spindle with a BB30 bottom bracket (if I have that correct)?
    Dec 2009
    Enduro makes an Italian threaded BB for DUB spindles.
  1. Quickie about BB's, cranks and italian threading
    By deartist7 in forum Components, Wrenching
    Last Post: 5 Days Ago, 07:42 PM
  2. SRAM PF30 DUB BB same for road and MTB?
    By alxrmrs in forum Components, Wrenching
    Last Post: 4 Weeks Ago, 08:57 PM
  3. BB30 different standards? threaded vs non threded
    By evs in forum Bikes, Frames and Forks
    Last Post: 07-29-2014, 07:35 AM
  4. Campy outboard BB cups, UT cranks, and Italian Threading
    By Ride-Fly in forum Components, Wrenching
    Last Post: 06-05-2012, 10:05 AM
  5. Guerciotti Frames: Italian BB's and Eng BB's
    By r_mutt in forum Other Builders
    Last Post: 08-24-2011, 12:55 PM
