Sram etap shifter clamp
Results 1 to 11 of 11
    Nov 2005
    I want to replace the bolt on a red etap rim brake 11sp shifter clamp and not sure of the correct clamp. I bought the group used and noticed the head on one of the bolts was slightly stripped. I secured on the handle bar everything torqued up to spec. I changed the bar and when tightening got the dreaded spinning and no tightening. I got it to where it wont move but its not to spec. Any body know the correct clamp and can I leave everything in place and just replace the bolt? Thanks in advance.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Just look it up in the spare parts catalog. The bolt comes in a kit with the clamp. Google the part number.
    I don't know if you can buy it anywhere separately. Maybe from a SRAM dealer.
    In my experience, anytime you remove the clamp bolt, it's a real b!tch getting it back in. So don't expect to be able to do it in place.
    https://www.sram.com/globalassets/do...pc---rev-i.pdf
    https://www.servicearchive.sram.com/..._noembargo.pdf
    Nov 2005
    Thanks for the reply. I have looked at those 2 catalog parts lists. Is this the part I need https://www.amazon.com/Sram-Shifter-...dp/B00EPGWNFK? Thanks.
    Oct 2013
    One can get a replacement bolt at a hardware store, but I don't think it's the bolt as you stated & if so, you'll need to take everything apart unless you retap to a bigger bolt in place.
    BANNED
    Nov 2005
    Its just the 5mm hex head on the bolt that is stripped. I have everything in position and semi tightened but not to 5nm spec and was hoping to just swap out the bolt. I guess I could take the bolt out and take to the hardware to match but I want to make sure I don't need anything "special" to make it work.
    tlg
    tlg is online now
    May 2011
    Quote Originally Posted by rlrj View Post
    If this is the type of clamp you have, then they're just normal bolts. One difference is they are low profile head. You won't find those at a regular hardware store. A full size head might stick up a bit above the shifter. Try Ace Hardware, they have the best selection of metric hardware and will have these. And get them in stainless.
    Also, if this is the type of clamp you have, swapping it in place should work. And don't forget the Loctite.
    If this is the type of clamp you have, you won't find them anywhere. They're not standard bolts. They're actually nuts (hollow bolts).
    This type of clamp springs open when you remove the 'bolt' making them difficult to get back in.
    Nov 2005
    Thanks for the help. I'll take the shifter off and see which one I have. I'm sure it will be the 2nd one just to give me added fun. lol...
    Nov 2005
    Cool
    Just an update. It was the 1st type of clamp, found a set online for $20 and replaced both sides. Very simple, I panicked for nothing.
    Reputation: rudge66's Avatar
    Mar 2019
    Just for my future reference, what is the correct torque for this clamp on carbon bar?
    Thanks.
    rotate avatar left for correct road fit position
    Nov 2005
    Quote Originally Posted by rudge66 View Post
    Thanks.
    On the sram tech manual it calls for 6-8nm. I used 5nm same as for the stem I'm using. Doesn't seem like it is going to move and I use 5nm on a set of di2 shifters on another bike same bar and they haven't moved in 4 years.
    Mar 2019
    Thumbs up
    @ rlrj Thanks. Agree with backing off a bit too .
  1. Current Sram Etap vs upcoming etap 12 speed
    By Cni2i in forum General Cycling Discussion
    Last Post: 02-09-2019, 11:11 AM
  2. A good innovation - SRAM eTap
    By OldChipper in forum General Cycling Discussion
    Last Post: 02-13-2016, 02:39 PM
  3. SRAM Red eTap - actual weights and installation
    By MMsRepBike in forum Components, Wrenching
    Last Post: 02-06-2016, 07:09 PM
  4. SRAM etap realease dates
    By Rashadabd in forum SRAM
    Last Post: 01-20-2016, 07:55 AM
  5. SRAM Red eTap Official Release
    Last Post: 10-22-2015, 03:38 AM
