SRAM Force 11spd. shifter compatibility with Force 10 spd. rear derailleur
Results 1 to 11 of 11
    Mar 2012
    Has anyone tried this combination with any success? Of course with 11 spd cassette.
    Nov 2013
    Im also curious to know if this combo works...
    Mar 2012
    I have taken the plunge and ordered right/rear shifter,11spd. Cassette and 11 spd. Chain
    I'll post results once I've completed install.
    In th mean time "Get out and Ride"
    Jan 2008
    Supposedly the 10 speed and 11 speed derailleurs are the same for SRAM. The difference is in the levers. It was somewhere on Velonews where I saw the article.
    Jan 2008
    Quote Originally Posted by jamiskibum View Post
    Isn't the different hood shape going to bug you?
    Mar 2012
    Will comment on that as well. Hadn't considered the shape would be different!
    Nov 2013
    the shape is a bit different, the feel is completely different, Im not sure if you can install the new gen hood on the old shifters.
    Nov 2013
    update????????????????
    Mar 2012
    Hi Manny
    Still waiting for shifter
    Nov 2013
    I was talking to my lbs and he said it should work, as soon as Im done with my other bike I will try to get this going, so prob. in a week or 2.
    Mar 2012
    Well here we go shifter finally arrived!
    Going to call this "The Mongrel"
    Using the wheel and Campy Record 11S 12/27 cassette from my Time, as well as a Chorus 11S chain with lessthan 1000kms ( this chain did not shift as nicely as Record 11 on my Campy bike)
    Rear derialleur is a new Sram Force 10 spd WiFli
    Rear shifter is a new Sram Force 11,front is original Force with a Red FD.
    After setting limit screws and installing chain I gingerly turned crank and clicked down once,nothing, added tension till we got a shift ,down to the middle gear,up one,a little slow dropping down the cassette ,backed of 1/2 turn on tension, up 1,down 1,perfect chain drop between gears, all the way down to granny SWEET , all the way up 1 at a time PERFECT,
    Onto the big ring,Instant, down the cassette all the way to cross chain granny,NICE!!!
    Off big ring to little ring (full granny),instant but a little rub,back off low limit on FD till just touching. Up onto big ring (cross chaining) ,effortless !
    I'd have to say this set up shifts like a THOROUGHBRED!!!!
  1. Shifting issue, SRAM Red shifter, Force rear dérailleur
    By AJ88V in forum Components, Wrenching
    Last Post: 07-24-2013, 06:32 PM
  2. SRAM rear shifter - Force vs. Rival
    Last Post: 04-22-2013, 12:19 PM
  3. SRAM Force WiFLi Rear Derailleur
    By JRock457 in forum SRAM
    Last Post: 10-05-2012, 08:23 AM
  4. SRAM Red Rear Derailleur v. Force
    By woodys737 in forum Components, Wrenching
    Last Post: 10-04-2012, 05:46 AM
  5. Play in SRAM Force Rear Derailleur
    By dirtspin in forum Components, Wrenching
    Last Post: 07-16-2007, 10:55 AM
