SRAM Quarq for Campy 11 speed
Results 1 to 5 of 5
    Aug 2011
    Can anyone on here tell me if the SRAM Quarq GXP with standard SRAM 10 speed will work with Campagnolo 11 speed running gear.
    I have been told yes, apparently even Quarq themselves told my mate it will however I am far from convinced?
    Reputation: chase196126's Avatar
    Jan 2008
    I ran an SRM with SRAM Red chainrings and S900 crank arms on my 11 speed for a little bit last year and it worked just fine. I didn't have any issues with chains dropping or missing shifts.
    If you are really concerned about using the SRAM rings you could always get a set of FSA 11 speed rings or one of the other after market companies that make 11 speed specific rings. This past year I ran an FSA Gossamer SRM with the 11 speed rings and it worked great as well.
    Sep 2006
    I have been running my Quarq S975 with the stock chainrings using Campy SR 11 Speed (mechanical) for the last week or so (~200 miles) and it works just fine.
    Mar 2003
    No issues
    I have been using it for 18 months or so and generally no problems.
    Jul 2006
    Works fine. I have run that setup for a couple of years.
