SRAM red 10spd vs 11spd chainrings
Results 1 to 9 of 9
    Reputation: jmitro's Avatar
    Jun 2011
    Just bought a new bike with SRAM red/22 - front crank is the 11spd 53/39. I want to swap to SRAM red Quarq crank with 53/39 chainrings - does it matter if the crank was designed for 10spd SRAM red? Or is shifting performance affected by swapping from 11spd chainrings to 10spd chainrings?
    Reputation: AJ88V's Avatar
    Nov 2012
    The *research* I did indicates that it should not be a problem, but perhaps someone else has already done it and verified. I looked at multiple chainring manufacturers and they all indicated that they did not need to redesign for 11 speed.
    The 11 speed chain is narrower, but most of the width was taken out of the side plates to make it thinner, keeping the interior dimensions about the same. Because of this, the 11 speed chain is more flexible in twist and people have reported that the chain shifts better on the front than the old 10 speed. The cage on the SRAM 22 FD is narrower than the 10 speed. I am currently running a Force22 FD on a 10 speed setup and the travel works just fine.
    Hope this helps a little.
    Jun 2011
    According to SRAM rep on the phone today, the crank spiders are identical; just need to swap chainrings to go from 10 to 11 spd and vice versa
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    People have been using "10 speed" cranks with Campy 11 for many years.
    If you're buying a new Quarq crank, and it has a 11 speed version, buy that one. If not, don't worry about replacing the pricey rings - it will work fine.
    Reputation: 32and3cross's Avatar
    Feb 2005
    Actually I have found that using 9 speed rings with 10 speed makes for really crappy shifting in the front. i have no idea if that is true for 11 speed but I would guess so.
    Apr 2011
    Quote Originally Posted by 32and3cross View Post
    Which is pretty bizarre when you consider that many cranks are 9/10 marked.
    I doubt the problem was your rings being the wrong speeds. I've done a lot of 9 to 10 conversions for people without ever seeing an issue. That includes my own bikes.
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    I want to do the same as the OP. 10 speed chainrings with 11 speed everything else. With the spacing being closer on the cogs of an 11 speed cassette, I assume that I should be using an 11 speed chain. Correct?
    If you try to fail, and succeed, which have you done?
    Jun 2011
    Quote Originally Posted by redondoaveb View Post
    yes, 10 spd chain won't shift as well
    Jan 2011
    Quote Originally Posted by jmitro View Post
    Thanks for the confirmation.
  1. Replies: 0
    Last Post: 07-01-2013, 06:53 AM
  2. are sram red chainrings compatable with shimano chainrings ?
    By joker in forum Components, Wrenching
    Last Post: 12-17-2012, 09:36 AM
  3. Replies: 4
    Last Post: 12-02-2010, 07:27 PM
  4. campy 11spd chain tool for 10spd
    By tjjm36m3 in forum Campagnolo
    Last Post: 06-29-2010, 11:46 AM
  5. 10spd chain on 11spd record crankset
    By nismosr in forum Campagnolo
    Last Post: 10-11-2009, 04:11 AM
