Steel frame cable routing under BB
Results 1 to 19 of 19
    Aug 2013
    Bought a steel frame from a custom local well known builder.
    The FD cable guide guides the cable against part of the BB shell. Shifting is fine right now, but ideally should it be routed differently? Worried it might eventually wear down the paint or have more friction. The owner said cable sheaths arent necessary.
    See photo.
    Dec 2006
    They're not necessary. Of course the paint will wear but it's no big deal.. Some builders do insert sheaths in the groove if they fit, such as Richard Sachs. Either way is fine but if you want to go that route, just pilfer some from extra shift housing you have on hand.
    Reputation: velodog's Avatar
    Sep 2007
    Ain't nothing to worry about. Just ride and enjoy the bike and quit fretting.
    Paint wear=beausage, the beauty of use.
    Too old to ride plastic
    MDM
    MDM is offline
    Jun 2020
    Do yourself a favor and put on a set of Jagwire Road Elite cables. Running a bare cable over that bottom bracket shell is going to cause a lot of friction and negatively affect your shifting.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Looks like a friction nightmare.
    You can see on both cables where they enter the guides they make a sharp bend.
    The FD cable wraps 90į around the shell.
    The guides look like they're designed to perfectly trap grit and gunk. Clean them with a toothbrush frequently.
    Quote Originally Posted by MDM View Post
    +1
    Back when I used cables, Road Elite's were all I would use. Totally sealed and maintenance free.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Some of this stuff (cable liner) might help. Of course you don't need 30 meters worth:
    https://www.amazon.com/Jagwire-Black...dp/B0029LF1XO/
    PM me your address and I can mail you 6" worth if you want.
    What the what???
    Jul 2009
    Quote Originally Posted by jetdog9 View Post
    Perv...
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Neophyte
    Jul 2007
    Oh geez I didn't even realize. I said something similar in a work meeting once and my co-workers wouldn't let go of it for years.
    Nov 2014
    My Pinarello Gavia TSX is routed with even less. 2 loops to go through bare over the BB shell. Never a problem and no friction I can discern. Yeah, eventually they'll wear grooves in the paint, but we're talking under the bottom bracket.
    Feb 2002
    Yup. Go to any bike shop and ask them to snip you enough for the job. They will have lots of it on hand.
    Quote Originally Posted by 5DII View Post
    See photo.
    I had this same conundrum when I built up my Mondonico 2 years ago. I bought some of the cable housing, per advice here at RBR, but in the end decided to try it "bare". I don't have an issue with friction and shifting but what I do notice is if I don't ride the bike for a while and conditions are humid, light rust will form between the cable and shell. This can cause the first couple of shifts to be very stiff. So, I try to keep the area clean and hit it with some WD-40 occasionally. Next time I change cables will try the sheathing
    Cathedral City, CA
    Nov 2005
    On a steel frame that can lead to Rust...
    2016 Ritchey BreakAway (carbon)
    Full Campagnolo drivetrain - Chorus 11sp (50, 34 & 12-29)
    Zonda wheels
    Lezyne Super GPS w/Cateye speed/cadence & HR sensors
    Ritchey fork, stem, headset, bars and seatpost
    Fizik Arione VSX saddle
    Cinelli bar tape
    BeBop Pedals
    Previous:
    2001 Fisher Tassahara, Shimano 3x9 (given away)
    2004 Giant TCR-2, Shimano 105 2x9 (sold)
    2005 Ritchey BreakAway, Campagnolo Centaur 2x10 > 3x10 (stolen)
    Sep 2007
    Quote Originally Posted by flatlander_48 View Post
    Yep, and so can a rock chip caused by a tire kicking up some road debris. A bike's not a painting to be hung on a wall an looked at, it's a vehicle to be ridden and enjoyed.
    I've got a couple of DeRosa's since the mid 80's, with the cables running under the bottom bracket, one with the original friction shifting and the other has been updated to indexed 10 speed and no problem, they both shift fine and no rust issues. Yes the cable will wear thru the paint, but the cable rub will also polish the exposed metal keeping rust at bay.
    I've also got a late 70's or early 80's Miyata that I bought 2nd hand with brazed on above the bottom bracket cable guides, no problem. And this bike sees absolutely no maintenance. My wife has a mid 80's Univega, of which she is the original owner, which also has above the bottom bracket cable guides, and guess what, no problem.
    If you want to worry about rust on a steel frame focus on the brake cable guides on the top tube, they collect sweat and aren't as robust as a bottom bracket. They will not only rust, they will rot right off the bike.
    MDM
    MDM is offline
    Jun 2020
    Those look like those expensive Shimano polymer coated cables. How long do you think that coating will last rubbing on those unlined cable guides around the bottom bracket?
    I have generally have not had major issues with rust on my steel bikes, but I had a Torelli that always had problems with the rear brake cable stop. Every winter I had to wire brush the stop, treat with rustoleum and re-paint. None of my other bikes were as bad.
    Cathedral City, CA
    Nov 2005
    Iím a retired mechanical engineer. To me, the important thing is to respect your machinery. One way to do that is to take care of it. I put close to 6,000 miles on the steel BreakAway that I had before it was stolen and it didnít have one stone chip. Anyway, more importantly, Campagnolo supplies a plastic cable guide that attaches under the bottom bracket. It covers the entire curvature and clearly minimizes any wear on the cable and the degree of drag on it is consistent...
    Zonda wheels
    Cinelli bar tape
    BeBop Pedals
    Previous:
    Nov 2014
    I have the same take as Velodog concerning the cable routing under my Pinarello's BB. Probably 20+ years and never a problem.
    I don't think there's right and wrong answer here. If you want to use the sheath, that's fine, and if you want to run the bare cables as the builder imagined, that's fine too.
    Flatlander, steel bikes that have metal guides brazed on to the bottom bracket (like in the OPs photo) won't allow a plastic cable guide. So the question is do you use the guide bare or add some sort of sheathing
    Sep 2007
    Mechanical engineer or not, honest wear is not a sign of disrespect to machinery or a tool, it's a sign of use. There is a difference between wear from use, and damage from abuse.
  1. Replies: 7
    Last Post: 08-09-2015, 03:03 PM
  2. Cable rub in top tube for internal cable routing....
    By Dcmkx2000 in forum Components, Wrenching
    Last Post: 04-30-2014, 11:20 AM
  3. Replies: 3
    Last Post: 12-06-2013, 10:00 AM
  4. Replies: 2
    Last Post: 06-06-2013, 04:35 AM
  5. Colnago Cable Routing under BB
    By manandjoe in forum Components, Wrenching
    Last Post: 11-30-2006, 07:47 AM
