• 07-23-2020
    tinball
    Quote:
    Originally Posted by Notvintage View Post
    As much as I hate Specialized their carbon steerer tube plug design is brilliant.
    https://www.amaincycling.com/special...caAqOKEALw_wcB
    That's the one I now have in my bike. Worked like a champ. The only issue is the length. It's quite short. Around 40-45mm if I recall correctly. If you need to move your stem down 5-10 mm (without cutting the steerer), it's probably not going to fully support the stem in the steerer depending on the clamp height of the stem. Just be aware when using it.
    As a follow up to the slippage from my original post: None so far. A few rides outside and things are still nice and solid and smooth steering as well.
  • 07-23-2020
    ROAD&DIRT
    As much as I hate Specialized their carbon steerer tube plug design is brilliant. Time’s “quickset” system eliminates the need for the idiotic plug. That’s true brilliance, and a whole other story.
    I use a Specialized steer tube plug pictured in the above link... no issues, slippage etc. holds everything exactly as expected :thumbsup:
