Steerer compression plug slipping - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
  1. #26
    Sep 2014
    Quote Originally Posted by Notvintage View Post
    As much as I hate Specialized their carbon steerer tube plug design is brilliant.
    https://www.amaincycling.com/special...caAqOKEALw_wcB
    That's the one I now have in my bike. Worked like a champ. The only issue is the length. It's quite short. Around 40-45mm if I recall correctly. If you need to move your stem down 5-10 mm (without cutting the steerer), it's probably not going to fully support the stem in the steerer depending on the clamp height of the stem. Just be aware when using it.
    As a follow up to the slippage from my original post: None so far. A few rides outside and things are still nice and solid and smooth steering as well.
  2. #27
    Never Give Up!
    Mar 2009
    As much as I hate Specialized their carbon steerer tube plug design is brilliant. Time’s “quickset” system eliminates the need for the idiotic plug. That’s true brilliance, and a whole other story.
    I use a Specialized steer tube plug pictured in the above link... no issues, slippage etc. holds everything exactly as expected
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  1. Replies: 3
    Last Post: 04-17-2014, 10:25 AM
  2. Carbon steerer compression plug slipping
    By ssing20 in forum Components, Wrenching
    Last Post: 01-24-2008, 02:34 PM
  3. Best compression plug for carbon steerer?
    By thegood in forum Components, Wrenching
    Last Post: 09-01-2006, 07:17 AM
  4. Carbon Steerer + Compression Plug
    By nathasm in forum Bikes, Frames and Forks
    Last Post: 10-07-2004, 06:29 PM
  5. Carbon Steerer-tube's compression plug won't stay in place
    By dawgcatching in forum Components, Wrenching
    Last Post: 08-22-2004, 08:49 PM
