Stuck threadless stem
Results 1 to 8 of 8
    Apr 2008
    Hi, I have this older Dia compe stem that has apparently, an internal wedge or compression thingy that wonít release the steerer tube. I donít care about the stem as I am replacing it. Anyone have any method to release this stem?2015D831-501A-417B-BDE8-D0D7C1F234B3.jpg
    I am probably the last person to have received an email from Sheldon Brown! A very nice gentleman.
    2008 Specialized Roubaix Elite Triple
    105 Shifter/derailleurs
    FSA Gossamer Triple MegaExo
    BWW Blackset Race 11 wheels
    Continental Gators 25c
    Kool Stop Salmon brake pads
    Cateye Strada Double Wireless CC-RD400DW
    Sigma PC-9 HRM
    RADBOT-1000 rear strobe flasher
    Blaze 1/2w LED headlight
    Dec 2006
    If you don't care about the stem, then start drilling through the black bolt with progessively larger bits until there's nothing left.
    Reputation: velodog's Avatar
    Sep 2007
    Is something stripped and just spinning or stuck and won't budge?
    Too old to ride plastic
    Sep 2011
    A picture would be good, but in many cases with expanding wedges, you need to loosen the bolt a few turns then tap it. This should free things up.
    Dec 2017
    ^This is what I did to a stuck stem on a Trek I was working on. The bike had been sitting at a house by the beach for years. The cover that is supposed to be over the stem bolt was long gone.
    I loosened the wedge bolt, and leaving the Allen socket on I gave it a few good whacks with a mallet. It loosened right up.
    Oct 2013
    You should look at the picture, I never seen a stem like that before.
    BANNED
    Dec 2017
    Eek. I didnít see the pic the first time. Disregard what I said.
    Probably CX has seen one of these before and will chime in.
    May 2012
    Dremel cut two slots at 3pm and 9pm, whack stem just ahead of the steerer tube-should shear right off assuming the aluminum stem hasn't galvanized to the steel steerer tube.
  1. Master Link Stuck...very stuck
    By whatthefunk in forum Components, Wrenching
    Last Post: 10-23-2012, 09:57 AM
  2. Replies: 11
    Last Post: 12-14-2010, 08:42 AM
  3. 1" threadless to 1 1/8" threadless
    By joeallison in forum Components, Wrenching
    Last Post: 06-29-2006, 07:46 PM
  4. Threaded to threadless stem question
    By macbugs in forum Components, Wrenching
    Last Post: 10-26-2004, 04:45 AM
  5. Threadless stem question
    Last Post: 10-22-2004, 09:25 PM
