Swapping wheels with Di2 - have to have the same cassette? - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Reputation: multirider's Avatar
    Nov 2007
    I adjusted the B screw so the RD is quite close to the 34t and still shifting perfectly. Then swapped to the 32t. Not aligned well, so I ended up using the Di2 trim adjustments and did 6 clicks outboard. Shifts perfectly. Swapped back to the 34t, expected to have to adjust trim again, but it shifts perfectly. Well, actually, I had to adjust the FD, but the RD shifts perfectly. Not sure how that can be after adjusting six clicks for the other wheel, but it works. I actually have a third wheel set with a 30t on it and that works perfectly as well. Iím amazed. Apparently, the B screw was the problem, RD was too far away. Just a little adjustment of the trim. Iím very happy now! I appreciate the input, but as I thought since some gears were fine and others werenít, it was NOT related to cassette alignment. I recommend adding B screw adjustments to your analysis/diagnosis suggestions. Thanks, all!
  2. #27
    Reputation: Srode's Avatar
    Aug 2012
    Awesome, glad to hear you got it lined out!
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
  3. #28
    Aug 2012
    Quote Originally Posted by multirider View Post
    Your statement is incorrect. There is an "Automatic" option for detecting the size of the rear cassette. See attached pictures.
    Attachment 327603Attachment 327605Attachment 327607
    Which Garmin model is it that you have in the screen shot?
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
  4. #29
    Nov 2007
    Garmin Edge 820
  1. Replies: 10
    Last Post: 01-06-2020, 05:58 AM
  2. How many have to adjust derailleur after swapping wheels?
    By sqwk77 in forum General Cycling Discussion
    Last Post: 04-19-2011, 10:51 AM
  3. Talk about same old, same old ......
    By Live Steam in forum Politics Only
    Last Post: 10-20-2007, 01:58 PM
  4. Some same ol' same ol' for ya.
    By Arby in forum Commuting, Touring and Ride Reports
    Last Post: 11-07-2005, 10:09 AM
  5. Replies: 9
    Last Post: 01-03-2005, 01:46 AM
