Synchro Shift will not work
Results 1 to 3 of 3
    Feb 2013
    I upgraded my 9070 Di2 group with the new battery, updated all firmware and set the customize shifting in Etube. Pushing button twice on junction box will not shift between modes. It stays in manual mode. When I check battery level red light also comes on indicating manual mode so I believe I programmed it correctly.
    I searched and found a post with a similar problem a while back that was solved by unplugging battery. This did not help. Any other suggestions? Getting frustrated.
    Feb 2013
    Okay finally got it to work. Must have double clicked a hundred times and finally had success. Donít know what I did or if I could repeat it. Very finicky.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by sasquatch16 View Post
    The double click has to be fast and click.
  1. Di2: synchro or semi-synchro. Why choose?
    By BhSimon in forum Components, Wrenching
    Last Post: 02-20-2019, 03:50 AM
  2. Semi-Synchro and Synchro-Shift together?
    By kestrel242 in forum Components, Wrenching
    Last Post: 01-26-2018, 08:28 AM
  3. Synchro 8 DT upgrade to Ergopower 8
    By GKSki in forum Campagnolo
    Last Post: 09-14-2016, 12:10 PM
  4. Convert Campy Power Shift to Ultra Shift?
    By JLane in forum Components, Wrenching
    Last Post: 01-16-2012, 07:25 AM
  5. Campagnolo Chorus Synchro II
    By mj3200 in forum Retro-Classic
    Last Post: 04-09-2009, 09:07 AM
