Tarmac Di2 Front Der - Which Hole?
Results 1 to 3 of 3
    Jun 2005
    I'm wiring up a Tarmac SL4 frame with Di2, and I followed the diagram here:
    http://service.specialized.com/colla...tion-Guide.pdf
    It wants the wire for the FD to come out of the hole in the front of the seat tube. Then I guess my choices are to go over or under the front derailleur motor body, because the socket is on the back.
    It seems like routing the wire through the hole between the chainstays and then going straight up the seat tube would be simpler. Is there any reason to go with one or the other?
    Oct 2014
    I'm not sure how you are 'supposed' to do it.
    On my BMC GF-01 and my Volagi Viaje I used the front hole (with a grommet) and wrapped it around the seat tube and came in from the back. I didn't even have the option of the other hole (both have external FD cable routing).
    I didn't want to take a chance on the wire getting wrapped up in the front derailleurs moving parts.
    Forever a Student
    Mar 2014
    Front hole, wire goes behind and under, not over.
    I think there's a little clip on the back of the mech for the wire.
    It should exit underneath the clamp, not over it like you have now.
    And you should be using a plug from Shimano where the wire enters the hole on the frame.
    use a torque wrench
  1. Needs a ultegra 28 hole front hub!
    By per_thomasl in forum Components, Wrenching
    Last Post: 01-17-2014, 07:35 AM
  2. a 20 hole front and 24 hole rear rim??
    By blizzardrider in forum Wheels and Tires
    Last Post: 04-01-2010, 11:08 AM
  3. 18 hole front, 24 hole rear hub options?
    By indianabob in forum Wheels and Tires
    Last Post: 07-29-2008, 06:14 AM
  4. Which spoke pattern for 24h front, 28 hole rear?
    By hobiedog in forum Wheels and Tires
    Last Post: 10-30-2005, 12:30 PM
  5. 18 hole front rim
    By DannyBoy in forum Components, Wrenching
    Last Post: 07-26-2004, 12:58 PM
