Thought I had dreaded bottom bracket creaking and it turned out to be a screw...
Results 1 to 10 of 10
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    New gravel bike is aluminum with press fit (I think) BB... did a ride recently that included 8 miles of straight bumpies on hard dirt.
    On the next ride I noticed serious creaking any time real power was put into the cranks such as climbing, every single pedal stroke.
    I don't have the tool to take off or tighten BB, but I took the cranks off and cleaned/greased everything in case it would help. It did not.
    Then I noticed there's a screw that holds on the cable guides under the bottom bracket. It turned out to be pretty loose and I tightened it... creaking sound went away. Anybody else ever run into this one?
    Threadlock on the screw, perhaps?
    a real member's member
    Jul 2016
    "it's always somethin'."
    - roseanne roseannadanna
    Apr 2011
    I've had creak problem that I thought was BB. Turned out that my seatpost and seat tube contact surface was dry and each micro movement caused creak. Tiny bit of lube (aluminum post & frame) solved it.
    Oct 2013
    I had a creak, I greased everything and it went away!
    BANNED
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    I once searched for a creak under heavy load - sprinting - on a customers bike. Ended up being the rear QR skewer.
    Just shows that a creak when pedaling can come from anyplace.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Two different creaks (at different times). One turned out to be loose cleat bolts, the other was loose mounting on a trainer.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Creaks can be quite evasive and frustrating. I had a creak that sounded like it was from the headset. Turned out it was the seatpost.
    Neophyte
    Jul 2007
    And after return of creak and much tinkering with the bottom bracket... the source was definitely narrowed down to something in the rear axle :| .
    I think it went away for a little bit when I fiddled with that cable guide screw because I flipped the bike upside down and that shifted something in the axle momentarily. After greasing and tightening of thru-axle parts, seems okay.
    Reputation: Akirasho's Avatar
    you've pizzered one of the cycling gods.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    I will think of you today while riding my smooth, quiet steel frame, threaded BB Cinelli. 😉
    Seriously, though, my most challenging creak a few years back turned out to be clearcoat on the rear dropout. From the reputation of press fit though, it is the BB until proven otherwise.
  1. strange grub screw in bottom Bracket area
    By carrock in forum Specialized
    Last Post: 09-22-2015, 11:36 AM
  2. Replies: 62
    Last Post: 08-07-2011, 10:57 AM
  3. We had a cancer scare, but everything turned out ok!
    By nonsleepingjon in forum The Lounge
    Last Post: 12-06-2007, 05:09 PM
  4. Creaking bottom bracket
    By Tomwd3 in forum Components, Wrenching
    Last Post: 03-19-2006, 04:03 PM
  5. Bottom Bracket creaking problem on a trek 5500
    By crossracer in forum General Cycling Discussion
    Last Post: 08-12-2005, 03:04 PM
