Thread Locker question
Results 1 to 12 of 12
    Apr 2014
    I have a one-bolt carbon seatpost. The bolt for the saddle adjustment has thread locker on it. I've been using Prologo saddles now for 10 yrs & have found that with Prologo saddles it takes more time to set it up & multiple adjustments before finally finding sweet spot.
    Also I've had a few instances of the saddle slipping & tilting all the way back. I had to really wrench on it to stop that. I've been using this post on what will be the 3 yr mark. I plan on changing to a Shimano Pro saddle with a cut-out.
    The question is should I re-apply new thread locker to the seatpost bolt once I have the ideal position dialed in? How long does thread locker last especially if one is doing constant adjustments?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by stan01 View Post
    Yes reapply. It may work a 'little' bit the second time, but not likely enough. It get's brittle and just breaks away and doesn't do anything.
    Assuming you're talking about traditional blue loctite.
    There are other types which stay flexible and are reusable. I've never used them, but if it's something you think you'll be adjusting frequently, it may be worth a try.
    https://www.amazon.com/Vibra-TITE-VC.../dp/B008D6GHY6
    https://www.vibra-tite.com/threadloc...-3-threadmate/
    Oct 2013
    To reapply traditional locktite, you will have to remove the bolt for reapplication, correct?
    Most seat/seat post angles/installation will not retain their positions while you do this, will yours? If so, perfect. I can never get mine to say in a position once that bolt is removed.
    If not I would just use some medium locktite that is re-adjustable later.
    BANNED
    tlg
    tlg is offline
    May 2011
    Not necessarily. It's thin and liquid. If you loosen the bolt and drip some into the threads, it'll wick itself into the threads.
    Apr 2014
    Thanks guys. The post originally came with blue thread locker on it when I built up the bike. But as I said, during the initial set up, I had to make a ton of adjustments until I found the sweet spot.
    I'm switching over to a new saddle so once I've find the sweet spot for the new saddle, I'll just write down all the critical numbers & reapply new loctite to the bolt. Not sure but as I've gotten older, the last 10 yrs I've had 3 Prologo saddles. Its a love/hate relationship. Love it at the beginning & middle of the ride but I hate it after that. Just painful at that point for some reason.
    I'm hoping that this change will help. I used to be a Selle Italia guy & never had an issue with them. I've still got one but it needs to be re-upholstered. There used to be a member here that did that. I might try to find someone locally to do that.
    I've never used a post like that but I've only used grease and that is what the instructions have said for the one's I've read read them for.
    Are you sure you need to be using locktite at all?
    Sep 2011
    The Bontrager posts that use that terrible clamp need to be torqued to 16nm. Make sure you're getting it tight enough.
    Reputation: nova_rider's Avatar
    Sep 2005
    There are only two possible adjustments for the saddle, fwd/aft & tilt. It shouldn't be a guessing game. Once you find the position you like, either mark it on the rail or take some measurements to a fix reference on the frame so you can be spot-on every time.
    Thread locker is only effective until it is disturbed, so it should not dictate what you can/cannot do with the saddle. You may also want to consider some anti-slip between the clamp and the carbon interface if it is rotating.
    Oct 2013
    Quote Originally Posted by nova_rider View Post
    This has not been my experience, it will make the rotation of the bolt more difficult without re-application.
    BANNED
    Apr 2014
    The seat post came with blue thread locker on it from the factory. But I was never sure the thread locker was actually working because it took many adjustments before I got the saddle dialed in. As I recall, it took a week of adjustments. Also you can't use grease with thread locker. This is one of those instances where its one or the other but not both.
    Quote Originally Posted by 202cycle View Post
    Unfortunately its the same design that is used by Specialized & Ritchey also to name a few. Yeah it requires a heavy hand to prevent slippage.
    Feb 2002
    It get's brittle and just breaks away ]
    Stop the apostrophe abuse!
    What the what???
    Jul 2009
    This smack down brought to you by the letters K and I...
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
  1. reasonable cost for bicycle locker rental?
    By Bolo Grubb in forum Commuting, Touring and Ride Reports
    Last Post: 11-24-2008, 10:14 AM
  2. A poll: Pain Cave vs. Pain Locker
    By eyebob in forum Cyclocross
    Last Post: 09-27-2007, 04:31 PM
  3. Stanky Locker
    By filtersweep in forum Commuting, Touring and Ride Reports
    Last Post: 05-30-2006, 07:57 AM
  4. Bike storage & locker room for city riders?
    By sugarloaf in forum General Cycling Discussion
    Last Post: 08-03-2005, 10:05 AM
  5. bike commute: this is an office, not a locker room
    By NeedhamDave in forum General Cycling Discussion
    Last Post: 06-11-2004, 12:32 PM
