Threaded to threadless stem question
Results 1 to 3 of 3
    Jul 2004
    If I go from a 1" Shimano Ultegra threaded headset (height 37.6mm) with a 135mm stem with a -17 degree rise (parallel to the ground), and go to a new threadless fork (Kestrel EMS) with a Cane Creek S2 threadless headset (height 28mm) and I want to get as close to the previous setup, what degree rise stem should I get because of the difference in headset heights now ? I was thinking 130mm with a -6 or what if I got a -17 ?
    Feb 2002
    You'll have to do the math
    The headset stack height difference is relatively small compared to how much of the stem you have showing out of your frame in your current setup. You need to look at how high the bars are relative to the top of the head tube, and then put in the numbers for the stack height of the new head set (above the head tube) and how many cm of spacers you plan to run. See where that puts your bars and whether you need a stem with rise, and how much rise you need. You have not provided enough information to answer your question.
    can't be answered...
    You forget that the quill stem is not sitting directly on the headset, so the difference in the headset stack heights is irrelevant.
    You need to measure the height of the bars, vertically from the floor to the top of the bars and provide the head tube length, without the headset. From this info, an approximate stem angle and steering tube spacer combination can be calculated.
  1. The stem question, again...
    By Farmpunker in forum Components, Wrenching
    Last Post: 04-12-2005, 02:42 PM
  2. Threadless stem question
    By macbugs in forum Components, Wrenching
    Last Post: 10-22-2004, 09:25 PM
  3. Replies: 54
    Last Post: 10-02-2004, 03:37 AM
  4. Question for Ritchey stem faithful
    By Nessism in forum Components, Wrenching
    Last Post: 06-28-2004, 04:25 AM
  5. stem rise & length
    By C-40 in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:33 AM
