Thu Axles Carbon Dropouts
Results 1 to 4 of 4
    Reputation: Srode's Avatar
    Aug 2012
    So I picked up a disc thru axle frameset with Carbon Fiber dropouts (metal inserts for the threads. It didn't come with the axles, but stock uses some that thread in and clamp over like a QR skewer. So my question is, does any frame maker use carbon dropouts and traditional threaded axles? I'm a bit concerned about the abrasion on the head mating surface tightening a threaded axle.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    'brifter' is a lame word.
    There are tons of frames/forks w/ carbon dropouts for q/r wheels. That's what you're asking, right? Your worry is not an issue.
    I work for some bike racers
    and a bunch of skateboards
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Quite a few carbon forked bikes have thru axles or thru quick releases (uses a quick release that threads into a fixed drop out). As CX said, no worries. Just make sure to get the correct axle and you'll be fine.
    Sent from my SM-G977U using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Aug 2012
    Question was Thru axles without the QR lever with Carbon Fiber fork and rear triangle ends (can't call them dropouts I guess). So just screw in and tighten axles.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  1. Hey Gutfiddle!!! check your front porch on Thu
    By Dave Hickey in forum The Lounge
    Last Post: 07-15-2009, 03:59 PM
  2. Don't tell anybody but Terry B's B-day is Thu.
    Last Post: 02-03-2009, 10:21 AM
  3. Friday Skills Rides - Moved To Thu This Week
    By bikerbert in forum Northern California
    Last Post: 09-17-2008, 06:55 AM
  4. Amgen Tour of CA - Thu 20% off Jerseys
    By Strings in forum Hot Deals
    Last Post: 03-03-2008, 06:58 PM
  5. phx thu nites
    By YuriB in forum Commuting, Touring and Ride Reports
    Last Post: 12-08-2006, 03:23 PM
