Tiso 12 speed wireless electronic group
Results 1 to 25 of 30
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    * not actually a Rock Star
    Oct 2011
    lol just read it over at WW forum (and bikeRadar) and I was just making the same comment... I wouldn't know what to do with an 11th speed, more so with a 12th !!! ;)
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Remote control lol... I'm gonna change my gears from the couch!
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by DrSmile View Post
    Or you can change your buddies gears when he ain't looking.
    Velocipediologist
    Reputation: metoou2's Avatar
    Mar 2009
    finally I'm gonna win that field sprint!
    Anphaque II
    Reputation: cda 455's Avatar
    Aug 2010
    Quote Originally Posted by metoou2 View Post
    America's greatest threat: Congressional liberal Democrats
    Crimes Against Humanity: The History of The Democrat Party
    Cathedral City, CA
    Nov 2005
    I don't think that's the case. If you pair with another Bluetooth device, I believe it will only communicate with that device. However, regardless of whether it is 2.4GHz or Bluetooth, all you have to do is turn them off like your smart phone.
    Anyway, after riding EPS and subsequently lusting after it, to me wireless brings very little to the party other than some additional potential problems. AAA's? Really?
    2016 Ritchey BreakAway (carbon)
    Full Campagnolo drivetrain - Chorus 11sp (50, 34 & 12-29)
    Zonda wheels
    Lezyne Super GPS w/Cateye speed/cadence & HR sensors
    Ritchey fork, stem, headset, bars and seatpost
    Fizik Arione VSX saddle
    Cinelli bar tape
    BeBop Pedals
    Previous:
    2001 Fisher Tassahara, Shimano 3x9 (given away)
    2004 Giant TCR-2, Shimano 105 2x9 (sold)
    2005 Ritchey BreakAway, Campagnolo Centaur 2x10 > 3x10 (stolen)
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Interesting in it's own way, but this particular entry will flatline. IMO they'd have had better luck if they hadn't tried for wireless. One battery to charge every now and then? OK. A set of them to fuss with, that'll need recharging / replacement at different rates? seems like a pain.
    Any word on what carrier they're shoving 12 cogs onto? Did they invent the negative-dish wheel yet?
    A good habit is as hard to break as a bad one..
    Banned forever.....or not
    Aug 2002
    I'll wait until they come out with an 11-23
    PS "D-Cells" would last longer
    Dogbert.
    I>U
    Cathedral City, CA
    Nov 2005
    Quote Originally Posted by MR_GRUMPY View Post
    PS "D-Cells" would last longer.
    Yes, but you can't package them as efficiently...
    Zonda wheels
    Cinelli bar tape
    BeBop Pedals
    Previous:
    Moose > Clydesdale
    Aug 2012
    Quote Originally Posted by danl1 View Post
    I was wondering the same thing... And if its the same carrier, they are they using an even thinner chain?
    Matnlely Dregaend
    Jul 2006
    They're using thinner spacing and thinner Ti cogs on a standard 10 speed hub. They use a Campagnolo 11 speed chain! Also an 11-29 cassette is mentioned, my guess would be 11-12-13-14-15-17-19-21-23-25-27-29.
    Cathedral City, CA
    Nov 2005
    I would imagine that you would replace them as a pack. In the past I've had devices that had 4 rechargeable C batteries. I used them as a group and charged them as a group. Besides, unless you put a meter on each battery, you wouldn't be aware of a possible difference anyway.
    However, to me the issue is recharging, assuming that the batteries are not alkalines. All of the chargers that I remember will accomodate 2, 4 or 6 bateries. If the Tiso battery pack requires more than that, you would need more than one charger or charge serially with one charger.
    Zonda wheels
    Cinelli bar tape
    BeBop Pedals
    Previous:
    δanned
    Reputation: SauronHimself's Avatar
    Nov 2012
    Twelve cogs are overkill. I hardly find enough use for my ten-speed cassette.
    Short answer to your question: No. It will not make you faster. It's about gear ratios and your power output. Moreover, the added mass might slow you down a bit.
    Velocipediologist
    Mar 2009
    Quote Originally Posted by SauronHimself View Post
    might want to check your sarcasm meter............me thinks it's broke
    (my comment is NOT sarcasm. use as directed. results may vary)
    Anphaque II
    Aug 2010
    I apologize if the question is elementary:
    I often wonder; Since pro tour bikes have a minimum required weight, wouldn't putting a triple be easier than trying to squeeze in more cogs?
    Since it's possible to skip gears while shifting (Like with Campagnolo shifters), couldn't a set up (gears) be designed to achieve similar results?
    Have the two largest chainrings to be, for example, a 54T and a 50T while the smallest chainring be the usual 39T.
    You math wizards and gears experts help me out here!
    Have it to where an 11 speed is set up so that the middle chainring acts like a gear splitter, for example. Of course that would mean the left shifter will be used much more than before. I can definitely see gear splitting being beneficial while climbing as well as TT'ing.
    With e-shifting, that would be a sweet set up !
    Reputation: Ventruck's Avatar
    Mar 2009
    Quote Originally Posted by cda 455 View Post
    I'd think the higher risk of chain dropping says nay to triples (Andy Schleck screams "nooooo!"). That, and dumping a cassette is faster than changing rings in some scenarios.
    For the whole "12 is teh uselessness!!!11!1!"....as long as it's reliable, a 12-25t with the 18t and 20t cogs (so 12,14,15,16,17,18,19,20,21,23,25) would be pretty nice imo. In climbing situations, just having that more exact gear could make all the difference.
    Noq I don't mean to bash Tiso, but they made an incredibly meaningless product (regards to wireless) as an attempt to have their breakthrough in the component industry. The finish on the levers and RD is a joke. Sounds like it can create more problems than solve. The big 3 will show up with their 12 speed whenever they feel it necessary.
    Anphaque II
    Aug 2010
    Quote Originally Posted by Ventruck View Post
    Good points on the chain drop issue.
    Thanks for the feedback.
    Cathedral City, CA
    Nov 2005
    I don't think it would help the pros that much. They tailor the cassette to the given conditions; something most recreational riders rarely do. Also, when there is a lot of climbing along the course, some will opt for compact set ups, not triples.
    Zonda wheels
    Cinelli bar tape
    BeBop Pedals
    Previous:
    The writeup I saw didn't explain the full battery config, but I'm assuming there's one battery pack that powers both mechs, and something else to manage the shifters. Sensibly, the shifter batteries could go a lot longer without charging than the mechs. If someone cared to maximize the life of their batteries, they'd want to wait until they were more nearly discharged, so charging differently.
    Yeah, for the sake of a few AA rechargeables, that's probably absurd. OTOH, that would mean at least 6 cells, and 4 is a more common number for chargers, and we can probably futz over the front battery case and what to do with it so it's reasonably discrete but readily accessible.
    Given the choice, I'd have a wire.
    Cathedral City, CA
    Nov 2005
    The BikeRadar article said AAA batteries...
    Zonda wheels
    Cinelli bar tape
    BeBop Pedals
    Previous:
    δanned
    Nov 2012
    My post wasn't sarcastic. Maybe I just made too much sense.
    So it does - I misread AA somewhere, and that seemed consistent with the DT control box in the pic.
    Either way, the complaint is still there, wrt to the battery box to power the shifters - unless they're managing to bury them in the lever bodies. but that sounds like a potential PITA for charging, and even more batteries than are really needed. Still thinking that a wire is a better solution here.
    Apr 2008
    I'm not really one for 12 speed, or electric, but I like this kind of thinking,
    "...Tiso does specifically mention that the system can be set to work with current Shimano, SRAM and Campagnolo 10- and 11-speed drivetrains, too."
    Don't mind me, it's just the online disinhibition effect typing.
    Jun 2007
    Why would this be? I ride both, and haven't seen any difference. Are the limit screws harder to set on a triple? (no, of course not). Is the chain line worse? Not really. Maybe I've just been lucky?
    He was running a triple when he dropped his chain?
    This I can believe.
