Tool to tighten front center lock (that houses the rotors)
Results 1 to 7 of 7
    Sep 2014
    Question Tool to tighten front center lock (that houses the rotors)
    Hey guys,
    I run a Pivot Vault Ultegra 6800 Di2 with Hydraulic brakes and while riding today noticed that there was some play with the center front rotors which are center lock.
    Anyhow, I took off the wheel and hand tightened it which fixed the problem for the time being.
    So my question is this:
    What tool do I need to get to really tighten it so it doesn't happen again?
    I found this:
    Amazon.com : Park Tool Cassette/Rotor Lockring Removal Tool - FR-5/FR-5G : Bike Hand Tools : Sports & Outdoors
    But I'm not 100% sure it'll do the job.
    Thanks in advance for the help!
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    Yes. It need to be *way* more than hand tight.
    Fortunately, the same tool works for centerlock rotors and cassettes at the back, so you'll get double-duty out of it.
    Sep 2014
    Thank you!
    'brifter' is f'ing stupid
    That tool doesn't work if you have a 15mm or 20mm thru-axle. You need this:
    #promechaniclife
    Sep 2014
    What's that tool called? by chance, could you link me on amazon.com...
    Jun 2006
    Quote Originally Posted by ThinkerBike View Post
    That's the Park Tool BBT-9. "The BBT-9 also fits rotor disc lockrings which use 16 external notches."
    There's the something new I needed to learn today! Thanks.
    So, if your rotor lockring has 16 notches around its outside diameter, then you need the BBT-9. (Which doubles as a Shimano external bearing cup bottom bracket tool.)
    If it's thin and smooth around the outside diameter and the notches are on the inside of the ring, you'll need the FR-5, linked to in the original post.
    Sep 2014
    Yep, this is exactly it! Thank you!
  1. lock ring tool comaptiblility
    By prometheus in forum Components, Wrenching
    Last Post: 04-10-2011, 09:19 AM
  2. what tool to use to tighten lockring on...
    By ocd in forum Fixed/Single Speed
    Last Post: 02-17-2009, 07:51 PM
  3. lock ring tool....
    By npoak in forum Fixed/Single Speed
    Last Post: 05-17-2007, 01:22 PM
  4. Lock Ring and BB Tool for Bianchi Pista Concept
    By Hillen in forum Fixed/Single Speed
    Last Post: 12-01-2006, 01:49 PM
  5. What Tool To Tighten Lockring?
    By AppleCyclingComputer in forum Fixed/Single Speed
    Last Post: 01-15-2006, 10:22 AM
