Topeak Joe Blow Mountain pump and road tires...
Results 1 to 2 of 2
    Apr 2013
    Question Topeak Joe Blow Mountain pump and road tires...
    Hey guys,
    I have a Topeak Mountain pump but I just got my first road bike today so I'm trying to decide if I need a second pump.
    The gauge only goes up to 75 or 85, so I'm wondering if the pump will still work for higher pressures. I am planning to get a dedicated gauge if so rather than having another pump sitting around.
    Has anybody tried this? Sorry if it's a silly question.
    Thanks!
    Reputation: looigi's Avatar
    Nov 2010
    The force required to compress a pump is determined by the diameter(area) of the piston and the pressure. Bigger pistons require higher force for a given pressure. Pumps for mtb tires have bigger piston diameters to pump more volume which is good for filling the relatively large volume of mtb tires. Road tires have much less volume and run higher pressures, so road pumps usually have smaller diameter pistons which make it easier/possible to reach the higher pressures of road tires.
    ... 'cuz that's how I roll.
  1. Topeak Joe Blow Pump Leaking?
    By hawker12 in forum General Cycling Discussion
    Last Post: 04-30-2016, 07:33 AM
  2. use mini road pump for MTB tires?
    By PoorCyclist in forum Components, Wrenching
    Last Post: 09-01-2011, 06:21 AM
  3. Shortening a frame pump (Topeak)
    By desurfer in forum Components, Wrenching
    Last Post: 08-03-2010, 07:21 AM
  4. Topeak PocketRocket mini pump
    By pavedroad in forum Components, Wrenching
    Last Post: 01-17-2007, 11:37 AM
  5. Topeak JoeBlow Pro Floor Bike Pump
    By daniell in forum General Cycling Discussion
    Last Post: 10-17-2006, 09:13 AM
