Trek 5200 OCLV Head/Down tube joint
Results 1 to 10 of 10
    Nov 2014
    Anyone know if the junction between head tube and downtube on a Trek 5200 OCLV frame is hollow (continuous interior of tubes)?
    I have a broken rivnut fragment rattling around the downtube and the easiest way for me to remove it would be to remove the fork and drop it out of the head tube if the void continues from the downtube to the headtube.
    Thanks.
    'brifter' is f'ing stupid
    Yep, that will definitely work. You could also take the seatpost out and do it that way...even easier.
    #promechaniclife
    Nov 2014
    Thanks, CX.
    So you think when the fragment goes into the BB area it can get past the BB spindle and head into the seat tube?
    Absolutely. There are no barriers/internal walls anywhere in Trek OCLV frames.
    #promechaniclife
    Nov 2014
    but, but, but ...
    You think the fragment will get buy the BB spindle and/or there isn't a BB plastic sleeve in the way?
    The bb shell is much bigger than whatever bb unit you can install in the frame. Unless there is a bunch of grease in there and the rivnut gets stuck in that it'll come out.
    #promechaniclife
    Nov 2014
    Good to know. Hopefully I can coax it around the bend and into the seat tube as that seems the easiest removal path.
    Just pull the post, turn it upside down and smack it a few times. It'll come out.
    #promechaniclife
    Nov 2014
    Success! Thanks, CX.
    Wouldn't drop out by itself or with some whacks, so must have been some grease holding it in.
    Finally saw it looking down the seat post and strapped a magnet to a long piece of copper tubing. Voila!
    I'm used to working on Columbus frames and I don't think this method would have worked on steel.
    Nice, good work!
    #promechaniclife
  1. Used Trek OCLV 5200
    By Tho66mas in forum Bikes, Frames and Forks
    Last Post: 04-20-2009, 05:54 AM
  2. Replies: 10
    Last Post: 09-16-2008, 06:32 AM
  3. Buying an old Lemond badged Trek 5200 OCLV???
    By paredown in forum Bikes, Frames and Forks
    Last Post: 03-30-2007, 11:03 PM
  4. Help place value on 1997? trek 5200 OCLV
    By icenoir in forum Bikes, Frames and Forks
    Last Post: 04-29-2005, 07:54 AM
  5. Help place value on 1997? trek 5200 OCLV
    By icenoir in forum General Cycling Discussion
