Trek Seat Mast Cap
Results 1 to 4 of 4
    Feb 2013
    Trek Seat Mast Cap
    I have a Trek Domane and am trying to determine whether I have the 135mm or 175mm mast cap. Does anyone know how they are measured? Could use a little more seat height and am maxed out with what I have.
    'brifter' is f'ing stupid
    Measure it. Bottom of the clamp thingy on the bottom of the post to the center of the saddle rail. If it looks like it has pretty much no offset it's the 5mm offset, if the saddle clamp is offset noticeably to the rear it's the 20mm offset. Those are the only 4 options.
    #promechaniclife
    Feb 2013
    Thanks.
    Reputation: Mitch@Trek's Avatar
    Jan 2019
    For the Domane (and Emonda), frames sized 56cm below will have a 135mm seat mast cap. Frames sized 58cm and up will have a 175mm seat mast cap.
    Sounds like a 175mm will help give you the extra height if you are using the smaller option. If you are already on the larger option, you'd need a larger frame at that point.
    Community Manager | Trek Bicycle Corporation | www.trekbikes.com
  1. Trek/Bontragger carbon seat mast- seat clamp keeps loosening???
    By Upnorth in forum Components, Wrenching
    Last Post: 08-28-2014, 02:05 PM
  2. Madone seat mast cap alternative?
    By blind in forum Trek
    Last Post: 12-19-2013, 09:22 AM
  3. Madone Seat Mast Cap Compatibility
    By SaxMan2001 in forum Trek
    Last Post: 05-18-2013, 06:44 PM
  4. 2010 6 Series seat mast cap slipping?
    By nor_cal_rider in forum Trek
    Last Post: 06-22-2010, 05:58 PM
  5. Replies: 10
    Last Post: 09-02-2008, 03:53 AM
