Two-bolt or four-bolt stems?
Results 1 to 10 of 10
    Aug 2004
    Is it OK to use a regular two-bolt aluminum stem (such as a Profile Design H2o) for clamping 31.8 carbon fiber handlebars? Are four-bolt stems better? Should I tighten the bolts until I hear a "cracking" or "crunching" sound (Just kidding!) Thanks very much for your advice!
    2-bolt OK, 4 is better...
    A 2-bolt stem will generally have larger M6 bolts that can be tightened more, but the 4-bolt models do a better job of distributing the clamping forces.
    Use of a torque wrench is a good idea, particularly if you don't have a good feel for the appropriate torque.
    http://www.boltdepot.com/fastener-in...ed-Torque.aspx
    B2
    B2 is offline
    You talking to me?
    Reputation: B2's Avatar
    Mar 2002
    According to Easton
    Quote Originally Posted by Wisbiker
    It appears that Easton is in the "Two Bolt" camp.
    http://www.eastonbike.com/downloadab...ess%20Tech.pdf
    Bryan
    interesting...
    My experience with 2-bolt models has never been as good as the 4-bolt. I've had problems with the bars slipping that I never have with the 4-bolt. Easton's new design may indeed work better than other 2-bolts, like the ITM's (which always slipped on me). Any owners with expereince?
    May 2002
    I use the ITM Millennium Carbon OS 2-bolt type on my road bikes. Never experienced any slipping in combination with the Millennium Carbon 31.8 bars. I do however make sure that the contact surfaces of both bar and stem are free of burrs and grease.
    Apr 2004
    I think Easton is just trying to sell their stuff. They had their 2 bolt stems on the market long before they crafted that marketing spiel.
    Ya, what ATP said...!
    Reputation: Fogdweller's Avatar
    Mar 2004
    Quote Originally Posted by C-40
    I'm using the Cinelli Solida/o Mag combo (a 2 bolt pattern) and haven't had any trouble. Though the bars are a carbon wrap over the standard aluminum Solida bar. Very stiff combo and pretty comfy.
    Sep 2004
    Cleaning is key...
    It is recommended by Barnett with ALL stems that you clean the contact surfaces on the handlbar and the inside of the stem mounting surface with rubbing alcohol or acetone (well ventilated area, yada yada). This is contrasted with the seat post in the seat tube, which should be lubed to prevent seizing.
    This will clean any contaminants or grease that could tend to increase slippage.
    But certainly a four-bolt system divides clamping forces more evently. If you are of substantial weight and tend to climb out of the saddle and push down on the bars, I can't see a two-bolt system as ideal.
    Also, when tightening, you want to tighten in a crossed-X pattern in a four-bolt clamp. Do NOT tighten to recommended torque on one bolt, then move to the next one. This applies uneven clamping force. I tighten all four to 10 in-lbs under recommended, then go to five under, then to recommended. Takes an extra one minute, but well worth it.
    And this is DEFINITELY a time when you want a torque wrench. Strip these bolts and you've got BIG problems.
    Mar 2004
    Two on a Road Bike is fine. .
    Four bolt stems are overkill on a road bike. . they really belong on mountain bikes. I have had (have) both. A Ritchey WCS and a Easton 2-bolt. They both work just fine. .
    Banned forever.....or not
    Aug 2002
    With a four bolt stem, it's easy to screw up and tighten the bolts too much. If you use a torque wrench ( or are careful ), a four bolt stem will be fine.
    Dogbert.
    I>U
  1. How does an expander bolt work?
    By Gerbila in forum Components, Wrenching
    Last Post: 10-02-2004, 05:59 PM
  2. Need quick answer Re: top spacers w/ carbon steerer, expander bolt
    Last Post: 10-02-2004, 06:05 AM
  3. Expander bolt in Carbon Fork
    By nick53nick in forum Components, Wrenching
    Last Post: 08-11-2004, 04:35 AM
  4. Only 2-bolt stems?
    By Spyky in forum General Cycling Discussion
    Last Post: 07-29-2004, 09:06 AM
  5. Stripped/stuck seat tube bolt
    By 633 in forum Components, Wrenching
    Last Post: 07-10-2004, 07:48 PM
