Is this type of dropout wear normal?
Results 1 to 4 of 4
    Aug 2017
    Hello,
    I have a 2018 Allez with low miles. Strava says about 510. I recently upgraded to some HED Jet wheels and noticed what I would consider to a fair amount of wear. It is only on the drive side dropout that faces the hub. The rest of the dropouts show very little wear at all. I have had some full carbon bikes with exposed carbon that haven't looked so deep. Is this type of wear self limiting? Could this be from the new wheelset's sharper teeth? I tend to keep the rear QR on the tighter side of things. Thanks!
    'brifter' is a lame word.
    Not a problem.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2017
    Thanks for the quick response.
    Feb 2002
    Quote Originally Posted by Cycleknox View Post
    Hello,
    [FONT=-webkit-standard][SIZE=3][COLOR=#000000]I have a 2018 Allez with low miles. Strava says about 510. I recently upgraded to some HED Jet wheels and noticed what I would consider to a fair amount of wear. It is only on the drive side dropout that faces the hub. The rest of the dropouts show very little wear at all. I have had some full carbon bikes with exposed carbon that haven't looked so deep. Is this type of wear self limiting? Could this be from the new wheelset's sharper teeth? I tend to keep the rear QR on the tighter side of things.
    Probably the first time a QR was tightened on the hub, the serrations on the hub lock nut made those impressions in the metal of the dropout.
  1. How Normal/Abby Normal Is This?
    By Akirasho in forum General Cycling Discussion
    Last Post: 04-18-2011, 09:07 AM
  2. rear dropout wear-wheel shift?
    By stevesbike in forum Components, Wrenching
    Last Post: 07-02-2009, 06:34 AM
  3. Std sliding dropout & hooded sliding dropout
    By lawrence in forum Bikes, Frames and Forks
    Last Post: 04-22-2008, 07:09 AM
  4. Chain wear = crank wear & cassette wear? true? false? bs?
    By jakerson in forum Components, Wrenching
    Last Post: 08-15-2006, 11:55 AM
  5. Replies: 22
    Last Post: 11-20-2005, 10:51 AM
