• 02-06-2012
    kokopelli99
    Ultegra 10-speed long-cage derailleur, 9-speed dura ace shifters, & 11-32 XT cassette
    Will an Ultegra 10-speed long-cage rear derailleur work with 9-speed Dura Ace shifters & 9-speed 11-32 XT cassette (crankset is double 46/30)?
  • 02-06-2012
    DaveT
    Quote:
    Originally Posted by kokopelli99 View Post
    Will an Ultegra 10-speed GS rear derailleur work with 9-speed Dura Ace shifters & 9-speed 11-32 XT cassette (crankset is double 46/30)?
    Maybe. If the B-screw on the rear derailleur can be adjusted so the upper jockey wheel will clear the large cog.
    Better yet, just get a 9-speed Shimano MTB rear der (the Deore or XT models work well) for a well-established, fine working combo that will handle an 11-34 cogset if needed.
  • 02-07-2012
    cxwrench
    just because the derailleur is long cage doesn't mean it will work w/ a 32t cog. long cage road derailleurs are designed to work w/ a 27/28t cog max, the longer cage is there to wrap the extra chain required for a triple. as DaveT said, an XT (9 speed) derailleur would work for sure.
  • 02-07-2012
    Kontact
    It might work if you put the B screw in backwards - if that's what you already have. Otherwise, like CX said, it isn't any better than any other Shimano road derailleur, long cage or not. Shimano "9 speed" or Microshift MTB derailleurs are better choices.
  • 02-07-2012
    ericm979
    I've had Shimano 9sp road triple derailleurs shift to a 30t cog without trouble. But you'd be pushing it. I think the answer depends in part on your frame's derailleur hanger geometry.
    The 10sp Ultegra and DA deraillers are set up for a slightly larger rear cog- the spec is 28t instead of 27t. So perhaps the derailleur would shift a 32t cog.
    But a 9sp MTB derailleur will for sure.
