Ultegra (11) shifters with XT (11) derailleur .will it work?
Results 1 to 12 of 12
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Are they the same throw?
    Thanks in advance.
    'brifter' is a lame word.
    Nope.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2005
    Thanks. You saved me from an impulse purchase. Looking for a derailleur with a clutch that will work with Ultegra shifters...(long cage)
    Oct 2017
    https://bike.shimano.com/en-SG/produ...-RX800-GS.html
    Sent from my Pixel 3a using Tapatalk
    Feb 2005
    You know if GRX will work?
    Feb 2005
    Quote Originally Posted by Finx View Post
    That’s really close, but it is a Medium cage. Looks like the GRX fits the bill if it is compatible. ETA is not until August, though.
    Oct 2011
    I believe Wolftooth make a tanpan ratio pully to allow this.
    Good luck
    Quote Originally Posted by stevoo View Post
    Good luck
    Pretty sure this is the case...I think they're about $45.00.
    Oct 2017
    I've used the TanPan in the past. It's a nifty gadget that does what it says on the tin. It's a bit fidgety to install, especially if you aren't enthused about doing your own wrenching.
    It probably goes without saying, but I'll say it anyway. Don't expect silky smooth shifting with the Tanpan in your cable path.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Shimano complicated compatibility between road and mountain drivetrains after their mountain drivetrains went to 10-speed and their road drivetrains went to 11-speed. Pull ratios were changed.
    Shimano 8-9-10 speed road drivetrains and 8-9 mountain drivetrains have the same pull ratios.
    In theory, the longer pull ratios of the newer groups make shifting more accurate. It would have been nice if they had changed them both at the same time and to the same pull ratio, but no.
    Oct 2013
    Shimano doesn't do what u want, they want to sell 'new systems'. ... oh yea... and not support their 'old systems'.
    BANNED
    Sep 2011
    This.
    I have a Tanpan that marries a Shimano 10spd (DA-7900) shifter to a Shimano 10spd Shadow rear derailleur. My experience is that if I set it up so shifting is smooth and precise from largest cog down to next-to smallest cog. However, shifting down to the smallest cog is a hit-or-miss. Half the time it will not shift to the smallest cog, half the time it will.
    But if I adjust the the rear derailleur (by relaxing tension) so that chain shifts into the smallest cog every time, then shifting action in the bigger cogs are not smooth. So I choose to adjust shifting for the bigger cogs and will live with it when it can't shift into the smallest cog since most of time I'll be using the bigger cogs anyway.
  1. Replies: 4
    Last Post: 02-07-2012, 11:15 AM
  2. Will a 9sp XT RD work with 9sp Ultegra Road Brifters?
    By chrisclougherty in forum Components, Wrenching
    Last Post: 10-15-2011, 12:46 PM
  3. 105 shifters, Deore Xt RD, 11-32,setup. result.
    By Ventura Roubaix in forum Components, Wrenching
    Last Post: 01-10-2011, 05:17 AM
  4. 2011 XT with Ultegra 6700 Shifters?
    By wedge962005 in forum Components, Wrenching
    Last Post: 07-17-2010, 04:38 PM
  5. Will XT shifters work with Tiagra?
    By superbad in forum Shimano
    Last Post: 07-30-2009, 09:21 AM
