Ultegra 6600 and 6800 parts compatibility question
Results 1 to 17 of 17
    Grumpy Old Man
    Mar 2010
    Iím in the process of updating one of my bikes from an Ultegra 6600 2x10 setup to an Ultegra 6800 2x11 setup. My bike has a braze on front derailleur mount. The donor bike that the 6800 parts came off of uses a clamp style. My question is this: will my old 6600 front derailleur work with the rest of the 6800 2x11 components and 11 speed chain? If not, do I need to source an FD-6800-F front derailleur or are the newer Ultegra series 2x11 mechanical derailleurs backwards compatible with 6800?
    Edit:
    Iíve been looking online for either 6800 or 8000 braze on derailleurs and they seem to be mostly out of stock. Is it worth the extra money to upgrade to a Dura Ace 9100? This is my ďforeverĒ bike so I do mind spending a little extra on it.
    Reputation: Srode's Avatar
    Aug 2012
    You should be able to get a used 6800 front braze on off Ebay or locally for maybe $30 shipped. The trim on it is nice, but I don't see any reason why you wouldn't be able to use your 6600 front either.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    +1 on Srode"s suggestion. Braze on FD-6800 easy to get used on eBay.
    Grumpy Old Man
    Mar 2010
    I managed to find a new FD-6800 braze on online for less than the few available on eBay so I went ahead and ordered it.
    Neophyte
    Jul 2007
    Excellent. Ultegra 6800 is SUPER solid.
    Grumpy Old Man
    Mar 2010
    Quote Originally Posted by jetdog9 View Post
    Glad to hear it. I was hoping to have the rebuild done by this weekend but i must be patient. Iím kicking myself for not checking such an obvious thing before starting the project. Good thing I have a few other bikes to ride while this one is out.
    'brifter' is f'ing stupid
    6800 is good stuff. I've had the best luck setting it by setting the low limit w/ the cable not attached. Then turn the low limit in 1/2-3/4 turn, attach the cable and then back off the limit however much you turned it in. This derailleur needs a bunch of tension and 'cheating' the limit helps, you don't end up using all of your inline or barrel adjuster. From high position you should a trim click that gets you 1-2mm, then you shift down to the small ring, then 1 more trick click that should be 3-4mm. If you don't get that much on the last trim click you're doing it wrong. Also before you attach the cable to the derailleur hold it in your hand and give it a tug while actuating the shifter a bunch of times. This will help seat the housing and ferrules. Don't forget the hit the last trim before anchoring the cable.
    #promechaniclife
    You probably know this but incase not; chances are you will need a new rear hub.
    Grumpy Old Man
    Mar 2010
    My Mavic Ksyrium Elite wheels have an 11 speed hub. I was using a spacer with the 10 speed cassette. Thatís one of the things I remembered to check before I started.
    cool, so yeah you're all set wheel wise.
    Grumpy Old Man
    Mar 2010
    Well this sort of blows. A week after I ordered the 6800 derailleur from bicyclebuys.com with 3 day shipping, they sent me an email saying that they didnít actually have the part I ordered, despite their website showing as in stock when I ordered it. Their solution was to suggest an SRAM derailleur that ďmight workĒ or I could wait a month for them to have an Ultegra 8000 derailleur in stock. I declined and ordered an 8000 from Colorado Cyclist. I wonít have a matching Groupset which I wanted because OCD but I should have a rideable bike by next weekend. Pretty much everything else is installed. Iím holding off on installing the bar tape until Iím satisfied with the position of the new bars. Other then that, itís just a matter of getting the front derailleur and chain installed and then adjusting the cable tension and limit screws.
    Limit screws, then chain, then cables/tension.
    #promechaniclife
    Grumpy Old Man
    Mar 2010
    Iíve found it to be important to have the chain installed when making final adjustments to limit screws. Am I missing something?
    Quote Originally Posted by b4_ford View Post
    For 'final' adjustment, yes. You can get very close w/o the chain and I've seen too many people shift into the spokes because they hadn't done any adjustment prior to installing the chain.
    #promechaniclife
    Grumpy Old Man
    Mar 2010
    Yep. Iím always cautious about that.
    Grumpy Old Man
    Mar 2010
    Happy happy joy joy. The derailleur I ordered from Colorado Cyclist arrived yesterday. Final piece of the puzzle so I can complete the reassembly.
    Follow the instructions explicitly. To. The. Letter. It's a fantastic derailleur but it's completely different from any and every other front derailleur you've ever touched. There are also a couple of good videos on YT showing how to set it up. If you have any questions lemme know and I'll walk you through it.
    #promechaniclife
  1. New Ultegra 8000 compatibility with 6800
    By alxrmrs in forum Components, Wrenching
    Last Post: 05-11-2020, 01:34 AM
  2. Ultegra 6600 vs 6700 vs 6800: My experiences
    By TiCoyote in forum Components, Wrenching
    Last Post: 03-28-2015, 04:45 AM
  3. ultegra 6800 with apex crank compatibility?
    By BlazingSlow in forum Components, Wrenching
    Last Post: 03-23-2014, 07:08 AM
  4. Chain wrap capacity with 6800 and use of Force 22 crank with 6800
    By nkranhold in forum Components, Wrenching
    Last Post: 02-11-2014, 08:41 AM
  5. Replies: 5
    Last Post: 07-09-2011, 06:16 AM
