Ultegra 8000 cable replacement preventive maintenance - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
  1. #26
    Oct 2013
    While this is true in an absolute sense, it bears little relevance to the issue at hand. Any standard grease will work and will not degrade the plastics used in cable liners or cable coatings.
    Do you know which plastics are used in cable coatings and housing liners? What is a "standard grease"
    Folks may want to peek at this document below if they want a more definitive explanation on grease compatibility with plastics. Also beware of "typical grease" and many rubber compounds.
    There are some very bad combinations, and many safe ones. Without knowing exactly what plastic and what grease is involved, I could not tell anyone "it's safe".
    What is safe, for me, is to use what the manufacturer of the cable system recommends.
    https://www.ecllube.com/resources-fo...20Plastics.pdf
  2. #27
    Aug 2015
    I usually do my Dura Ace cables every 2-2.5k. Only ever seen one strand frayed but I ride mostly flat terrain and might not shift as much as you. Even though I don’t see fray, shift performance degrades by this point.
  3. #28
    Oct 2013
    Here's another 2 page overview that discusses "Lubricants for control cables"
    and talks about that applications special requirements. Almost all their recommended lubes use PTFE
    https://www.nyelubricants.com/stuff/...rol_cables.pdf
    Nye’s fluorocarbon gels, for example, incorporate PTFE which creates a surface with a very low coefficient of friction and aids in supporting medium and heavily loaded cables to reduce wear.
    We also offer greases for push-pull cables. They feature a unique combination of silicone oils and PTFE gelling agents which provide excellent cable wetting, very low friction, and load-carrying capabilities.
  4. #29
    Sep 2011
    Quote Originally Posted by thisisthebeave View Post
    2-2.5k??? That's not even half a year for me. Not feeling it.
  5. #30
    Sep 2011
    Quote Originally Posted by Z'mer View Post
    I just use white silicone (the kind they use for machines in the food industry). Safe and nontoxic, no odorless, and very decent lubrication. I stay away from these "automotive" grease because of their smell and toxicity.
  6. #31
    'brifter' is a lame word.
    You'll get a feeling for how long yours will last after they do start to fray, then replace them based on that mileage.
    I work for some bike racers
    and a bunch of skateboards
  7. #32
    Sep 2011
    I put in around 10k-12k/yr spread out between 3 bikes primarily (fourth bike is a little bit of a trainer queen so no count). So what I do is buy a roll of "generic" Jagwire shift housing and a boatload of stainless steel shift cables. For grease, I use food-grade silicone. Honestly, I cannot tell the difference between the Dura Ace slickity-slick cables the generic stainless steel cable with silicone. Because i bought these stainless cables in bulk on ebay for cheap (like $1 per cable), I usually change them out yearly, not because they start to fray, but more like I just want to tinker with my bike. This approach saves me the worry of having to examine the cables, because when in doubt, throw in a new cable for $1 bux.
  8. #33
    Nov 2006
    Thanks everyone. I did read this earlier, but didn't respond. I'm not seeing how to look at the cable but I'll be the first to admit I don't know anything about road bike shifters. To me, these Ultegra 8000 seem to cover up the cable pretty well. And it is all internally routed, even through the chainstay.
    I was curious about trying new bars, so the shift-cable recommendation convinced me to go ahead and buy some and then I'll just take the shifter off so I can hold it in my hands and figure it out. Always nice to put on some fresh bar-tape also.
    I'm sensing a couple people putting digs on Shimano about this, but I like Shimano even if I should replace a shift cable every couple thousand miles. (I'm overweight in hilly Pittsburgh, so yes I shift a LOT.) I hope after doing it once, it'll be pretty easy to replace a cable every couple years.
    Thanks again!
  9. #34
    Quote Originally Posted by Wheelspeed View Post
    Thanks again!
    Pull the hood forward from the back (handlebar side) of the shifter. On the left side of the right shifter there is a small cover you can pop off and see the cable. Generally if it's frayed you'll be able to see it there.
  10. #35
    Reputation: Srode's Avatar
    Aug 2012
    Make sure you are in the small cog on the back when you look though, the wear that causes breaks most often happens at the end of the cable which isn't going to be as visible in the bigger cogs. When you are in the small cog you can also look inside the hole on the outboard side of the shifter and check for cable splintering. There I would shift from the small to the next smallest and back while looking at the cable.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  11. #36
    Again, passage of time has nothing to do with cable wear.
  12. #37
    Nov 2002
    What about these polished stainless steel cables? Do they give lower friction? I'm thinking maybe not when they have silicone grease on them.
  13. #38
    Reputation: Lombard's Avatar
    May 2014
    Probably not. Just make sure they are stainless steel, not the cheaper galvanized cables.
  14. #39
    May 2012
    Perhaps Di2 arose as a fix for cable eating shifters.
  15. #40
    May 2014
    Quote Originally Posted by Bremerradkurier View Post
    That would be pretty lame. Let me just say that while I dismiss most conspiracy theories, one has to wonder why Shimano hasn't been able to solve the cable eating shifter problem for 3 generations of components.
  16. #41
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    It's probably my #1 reason for going Di2 on all my bikes. I don't know if it's a conspiracy but it's a great selling feature.
    18,000mi. Ride year round in all conditions. Never replaced a cable. Never made a single shift adjustment. Shifting is exactly the same as day #1
  1. New Ultegra 8000 compatibility with 6800
    By alxrmrs in forum Components, Wrenching
    Last Post: 12-28-2018, 09:15 PM
  2. Shimano Ultegra 8000 is out
    By pmf in forum Components, Wrenching
    Last Post: 08-22-2017, 01:19 PM
  3. Preventive maintenance when caught in downpour
    By johninfairfax in forum Beginner's Corner
    Last Post: 08-17-2005, 04:46 PM
  4. preventive measures:stuck post or stem
    By Djudd in forum General Cycling Discussion
    Last Post: 02-13-2004, 03:58 PM
