Ultegra Crank Debonding
Results 1 to 11 of 11
    Bill Dobie
    Reputation: Bill Dobie's Avatar
    Jul 2014
    Hi Ya'll - Haven't seen much on the topic of Shimano Dura Ace and Ultegra cranks debonding on right side. Looks like the pretty "skin" on the outside coming apart from the "structural" part on the inside. Look up Thanks Shimano on Instagram. Tons of photos. Anyway looking to replace 3 year old Ultegra 10 speed and only finding 11 speed available. Will 11 speed cranks work with my 10speed components? Any others experience this issue?
    THX!!
    'brifter' is f'ing stupid
    Seen it a bunch. Unfortunately you're past the 2 year warranty. An 11 speed crank will work just fine.
    #promechaniclife
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    The only difference between a 10-speed crankset and an 11-speed crankset is marketing. Either will work fine with your setup.
    "Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital." - Aaron Levenstein.
    "With
    -- DCGriz, RBR.
    I think Shimano's official answer is: No. But so many people have done it no problem and I've never heard of it not working for anyone.
    You can also use 11 speed chains with 10 speed parts. No problem finding 10 speed chains so no need for that but I find 11 speed chains do shift slightly better even with all 10 speed stuff as compared to 10 speed chains. I don't think they last as long though.
    Banned Sock Puppet
    May 2014
    My last 11-speed chain lasted 6000 miles. The only reason I changed it was it had a stiff link I couldn't work loose. It had no measurable wear.
    "With
    -- DCGriz, RBR.
    Feb 2002
    Given that chain wear is heavily dependent on rider power output, that explains your long chain life Note that my chains last even longer
    Banned Sock Puppet
    May 2014
    Joking aside, when I used dry wax lubes, my chains showed wear at 2000 miles. Was I stronger then? I don't think so.
    "With
    -- DCGriz, RBR.
    yeah, so? Unless you also rode a 10 speed chain for the same distance under the same conditions and had the same or worse results that doesn't have anything to do with what I said.
    Banned Sock Puppet
    May 2014
    The chain I mentioned above that lasted for only 2000 miles was actually a 10-speed chain.
    Yes, I know not equal situations. But how much longer do you think the 10-speed vs. the 11-speed chain will last if all other variables are the same? My point is that other variables will make much more of a difference in chain life.
    "With
    -- DCGriz, RBR.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Was the point that dry wax lubes aren't any good? Not sure I understand what you're trying to say sorry.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by DrSmile View Post
    Basically yes, dry wax lubes are nowhere near as good at lubricating as "wet" oil based lubes.
    "With
    -- DCGriz, RBR.
  1. New Ultegra Crank or a 7800 DA crank
    By Har in forum Components, Wrenching
    Last Post: 06-22-2010, 06:20 PM
  2. Ultegra 9 spd crank with Ultegra 10 spd group...will it work?
    By filly in forum Components, Wrenching
    Last Post: 08-07-2005, 02:18 PM
  3. Old crank 42t, new crank 39t, cassette size advice?
    By T-shirt in forum Components, Wrenching
    Last Post: 10-29-2004, 03:30 PM
  4. Changing Triple Road Crank to Mtb Crank
    By caad5 in forum General Cycling Discussion
    Last Post: 07-09-2004, 07:02 PM
  5. Record alloy crank VS FSA pro team crank
    By boat in forum Components, Wrenching
    Last Post: 02-12-2004, 08:49 PM
