Ultegra r8000
Results 1 to 14 of 14
Thread: Ultegra r8000
    Jun 2020
    Ultegra r8000
    Hello, I went to clean my rear derailleur and I saw this. You see that the pulley are not aligned and the cage is bent. I never crashed my bike nor leaned and fall. I would think that this came out of the factory. I have no problem shifting, but I hear a skip not often. I wonder if this is a factory defect, I was thinking of taking it off and just straighten it myself. Do I have to be concern in a long run? Any input is appreciated.
    Oct 2013
    I really doubt that came from the factory that way. It's bent, I would take it apart and straighten everything out. I'd have a bike shop check your hanger and make sure it is in alignment.
    BANNED
    Sep 2011
    the cage is made of aluminum isn't? bending aluminum is a no no.
    Bring it back to the LBS and ask for a new one. LBS should be able to take a look at the derailleur and if they see no marks/scratches on the derailleur then they would have to conclude that you didn't crash the derailleur to cause the bent.
    Oct 2013
    One can bend aluminum to a great angle, .... once. One can bend aluminum a slight angle a couple of times.
    BANNED
    Mar 2010
    WRT bending aluminum, some aluminum, 7075, 2024, even 6061, won't bend at a "great" angle even once. Soft aluminum, 3000 series, others, you can bend a lot. For that cage, it can be bent back if careful and it has no sharp bends, which it appears to NOT have. IF you have no LBS to go to to get a replacement!!!
    Oct 2013
    How do you know what aluminum you have?
    BANNED
    Jun 2020
    Hi guys, thanks for your feedback. I thought those cages are not aluminium but steel. It's kinda weird how it's bent both side and only on the particular pulley. My bike never fell leaning nor crash (knock on wood). I tried straighten it up using long nose but it's really hard, I guess I have to disassemble it and bang it on the ground. From now on when I bike a new bike, I will check it before I take it out from the bike shop.
    Mar 2010
    You don't!
    Oct 2013
    Then the RD pulley housing is not 7075, 2024, even 6061, cause I straightened mine before. Your RD pulley housing may be different.
    I think with most aluminum parts you can tell by handling them if you can bend them or not. If you apply pressure and they are really stiff, don't keep going. But don't go too far, cause you ain't going back to kansas!
    BANNED
    Feb 2002
    Quote Originally Posted by Lougarou View Post
    I would straighten that, no question.
    Reputation: Srode's Avatar
    Aug 2012
    i'd try to straighten it but recognize it's going to be tough by eyeballing it. You can probably find a cage somewhere to replace it, but DRs are not that expensive either.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Jun 2020
    Yes, I might have to just replace the parts, but if not it'll be straight outta' compton thing. Thanks guys.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    That cage sure does look bent. And let's not confuse that with the hanger. The hanger is a sacrificial item that is meant to break before anything else. You don't indicate that the hanger is bent anyway, but considering that kind of damage on a derailleur cage, I can't image the hanger hasn't also been bent.
    As Srode said, derailleurs aren't terribly expensive. Hangers are even less expensive.
    "With
    -- DCGriz, RBR.
    Jun 2020
    Because of this, I went to search and I found this video https://www.youtube.com/watch?v=qtd4hI07whI. I wonder if all the Ultegra r8000 owners have the same issues. I came to conclusion that this is from the factory. I appreciate all your feedback guys. Ride safe.
  1. Replies: 9
    Last Post: 4 Weeks Ago, 08:17 PM
  2. Upgrading from Tiagra to Ultegra R8000
    By jsebastianorozco in forum Components, Wrenching
    Last Post: 08-28-2018, 06:17 AM
  3. Replies: 6
    Last Post: 07-12-2018, 07:59 AM
  4. Shimano Ultegra R8000 drivetrain missed the Boat...
    By factory feel in forum General Cycling Discussion
    Last Post: 04-09-2018, 11:07 AM
  5. Shimano Ultegra R8000 officially announced
    By cobra_kai in forum Components, Wrenching
    Last Post: 06-13-2017, 05:19 AM
