Ultegra vs Dura-Ace shifter durability
Results 1 to 20 of 20
    Dream It, Do It
    Reputation: Spectre68's Avatar
    Jun 2004
    About how many miles are you getting out of an Ultegra STI brake lever/shifter? My Shimano Ultegra shifters seem to consistently fail to start engaging to shift to smaller chainrings or smaller cogs around 5000-7000 miles.
    Are Dura-Ace shifters any more durable than Ultegra shifters? Especially in light of their price, shifters seem to wear out really quickly.
    Dirt Merchant Bikes
    www.dirtmerchantbikes.com
    Seattle area dealer for Turner Bikes & Cleary Bikes
    Oct 2013
    You need to clean them out with WD40 or something like that really soak them. There are other posts around here that actually get into what to do, look around.
    BANNED
    Reputation: Srode's Avatar
    Aug 2012
    Quote Originally Posted by Spectre68 View Post
    What kind of environment are you riding in? Are you sure it's not the shift cable? The shifters should probably last at least 10 times that long.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    KWL
    KWL is offline
    Reputation: KWL's Avatar
    Jan 2005
    This. Iíve got Ultegra shifters on my 1993 Bridgestone RB-1 that work just fine after WD40 flushing & relube.
    Ken
    P.J. O'Rourke: The Internet - whose idea was it to put all the idiots on earth in touch with each other?
    Miles are pretty much irrelevant and I doubt anyone is keeping track of how many times they shift.........but mine consistently fail around 10k and no Dura Ace is not better in my experience. However, my experience of about 60K miles and 6 blown right shifters is all with 10 speed.
    I do have an 11 speed bike now and that is still going fine at about 7k.
    I would say that I shift a lot more than the average rider. Weird you're only getting about half of what I do but I suppose it's theoretically possible you shift twice as much.
    .....and I'm 100 sure my shifters have just died not that they just need cleaning.
    'brifter' is f'ing stupid
    After 25 years in the business I can probably say with certainty that I've only seen a few Shimano shifters actually 'wear out'. For sure less than a dozen. It just doesn't happen.
    #promechaniclife
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    The two times I've had matching generation Ultegra vs Dura-Ace to compare have been Ultegra 6600 / Dura-Ace 7800 and Ultegra 6800 / Dura-Ace 9000. I don't think there is a durability difference.
    Aug 2012
    Man, that's just crazy - I don't know anybody who has that kind of problems. My rear DR cables lasted longer than that before I moved to Di2 on everything.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    jkc
    jkc is offline
    Jun 2014
    My Ultegra 6800 is getting "sloppy" at year six, ~40,000 miles. It's still shifting fine but getting a bit more play on the up shift compared to my DA 9000 that only had 1,500 miles and since replaced by Ultegra 8000 with less than 500 miles (it got killed after being rear ended a minivan and "pushed" for a few feet with me & bike pined underneath as the driver decided if she can flee the accident).
    Dream It, Do It
    Jun 2004
    Thanks to everyone for the feedback! Running out to get the economy sized spray can of WD-40 now!
    Dirt Merchant Bikes
    Feb 2002
    I just can't imagine this kind of failure rate. My current Chorus shifters have over 60K miles without a glitch.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I've never had a Shimano shifter break. They do enjoy eating cables and need a rear shifter cable every 1500 miles or so, but other than that, never a problem.
    Note that if there are cable fragments in the shifter, it can jam. Picking out cable bits out of a shifter is loads of fun - NOT!
    "Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital." - Aaron Levenstein.
    "With
    -- DCGriz, RBR.
    Feb 2002
    Another advantage to Campy shifters: they don't eat cables. I get about 25K miles per cable set, and typically it is fraying at the very end rather than in the shifter that triggers replacement. I have had them fail at the shifter as well. It is all about having a fundamentally better design.
    jkc
    jkc is offline
    Jun 2014
    Must be shifting a lot. I get a whole season or more before needing a cable replacement. The front can go for much longer but I normally change them out at the same time. That's been averaging around ~320 hours or 5.2k miles per year over the last three years (been on the low side since my last accident).
    Banned Sock Puppet
    May 2014
    Believe me, I am contemplating a switch if I can't get better life out of these cables. SRAM would be the easier switch as I could get away with just replacing shifters and derailleurs. Campy would require a full groupo and a new cassette carrier.
    One thing for sure. The bike I'm contemplating building up will have Campy Chorus 12-speed. I like the idea that I can get a 48/32 crankset. A rumor has it they aren't quite as durable as Campy of yesteryear, but it's still probably not too shabby.
    Not sure I understand what you mean by fraying at the very end. Wouldn't a cap prevent that?
    "With
    -- DCGriz, RBR.
    Aug 2012
    You would be a good candidate for GRX Di2 then, not 12 speed but zero issues with cables
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Reputation: Oxtox's Avatar
    Aug 2006
    put 23K on Ultegra 6600 shifters before selling the groupset, no issues.
    currently have 39K on a set of DA 7800, no issues.
    pmf
    pmf is offline
    Yeah, but these guys are talking about Shimano, not Campagnolo.
    Sep 2005
    Agree 5-7k miles is an unusually short lifespan for Ultegra shifters (assuming no abuse). Shifting issues at that point on most often due to gummed up works.
    I have some 'classic' DA 7800's (last exposed cable 10spd) with 13k miles that still shift as nice as ever.
    OTOH- I'm just now retiring some Ultegra 6600 shifters at about 20k miles due to wear. Still shifts but has gotten pretty sloppy (missed shifts, mushy feel) even with new cables/housings. Good WD-40 flush and re-lube brought it back twice but not this time. To be fair, the last 5k miles or so have been on my beater bike---so borderline abuse;)
    FWIW- 20k miles seems to be a pretty typical lifespan for Ultegra STIs among area cycling clubs. Of course, some riders are more tolerant of sloppy shifting than others, and some are harder on their gear than others. Consistent wet/dirty riding conditions can drive any mechanical device into an early grave. So can bad habits like routinely shifting without pedaling. And one guy I used to ride with had a nervous habit of shifting up/down while waiting at stoplights. The incessant clicking noises drove me nuts.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Oxtox View Post
    Both of those group sets were the generation before Shimano went with under the handlebar tape cable runs. 5700/6700/7900 is when the cable eating train wreck started.
    Nope, not interested in e-shifting. Next groupo will be Campy Chorus 12 or SRAM Force 22.
    "With
    -- DCGriz, RBR.
  1. Dura Ace 10sp vs Dura Ace 11sp?
    By giosblue in forum Components, Wrenching
    Last Post: 05-25-2014, 07:10 PM
  2. Dura ace or ultegra electronic vs dura ace mechanical ???
    By Bluspwr in forum Components, Wrenching
    Last Post: 05-12-2014, 04:16 PM
  3. Replies: 9
    Last Post: 03-26-2013, 06:46 PM
  4. Dura ace vs ultegra durability clarifications
    By omniviper in forum Components, Wrenching
    Last Post: 01-28-2007, 06:41 AM
  5. dura ace cassette durability?
    By dave962b in forum Components, Wrenching
    Last Post: 12-05-2004, 04:53 AM
