unknown brake pad set screw size???
Results 1 to 7 of 7
    Jun 2010
    I have fixed the problem but I'm just asking this out of curiousity. I replaced the brake pads on my '08 Tarmac Elite last night. The brakes are not Shimano but they are a very close look-a-like with no name. The set screw that keeps the pads from sliding out on the brakes requires a hex/allen wrench. The problem was, a 3mm was too big and a 2.5mm wrench was too small. I tried standard/english size wrenches and none of those fit either. I was perplexed. In the end I removed the set screws by grabbing the sides of the screw heads with pliers. Luckily they weren't too tight so this worked. Then I replaced them with the screws that came with my Shimano pads which are installed using a 2mm wrench. Anyway, have you heard of a screw head this size? If so, what size is it? 2.75mm?
    Feb 2002
    Torx?
    Quote Originally Posted by namillis View Post
    I'm guessing it was either 1) a Torx bolt or 2) somebody had stripped out a 2.5 mm by using a cheap wrench or bad technique.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    +1...those tiny set screws are easy to round out with an ill-fitting hex key, especially if they're gummed up.
    "Luminous beings are we...not this crude matter!"
    Jun 2010
    Good thoughts but...
    It's definitely a hex head, not torx, and its un damaged, no crud and not rounded out.
    Feb 2002
    Bad wrench
    There is virtually no chance it is anything but metric. I think the only suspects left in this equation are the allen wrenches you've been using or that your knock-off brakes have low grade parts.
    Jun 2010
    Bad Wrench,
    Since none of my metric or English hex wrenches fit (and I'm fairly sure there is no such thing as a 2.75mm hex) and I'm sure its a hex bolt that has not been deformed, I agree that it must be a cheap screw (or 4 cheap screws). The brakes work great so I'm not going to criticize them. I was really just putting this out there to see if anyone else had the same experience.
    Looking for my Amish Love
    Reputation: capt_phun's Avatar
    Jun 2004
    You don't even need those. A Belgian buddy was a Pro wrench for CSC & he took those out so when/if the pads wear down on carbon rims, the set screws won't gouge the carbon. He took them out of the brakes & threw them in the gutter. Your pads only come out aft, so how are the pads going to fall out anyways.
    Capt_Phun's Riding Blog:
    http://captphun.blogspot.com/
  1. What size screw thread does a...
    By jlandry in forum General Cycling Discussion
    Last Post: 01-07-2011, 10:59 AM
  2. Screw size for STI name plate?
    By M77PT in forum Components, Wrenching
    Last Post: 07-19-2009, 06:42 PM
  3. Bottle Cage Screw Size?
    By boblikesbikes in forum Colnago
    Last Post: 02-28-2008, 09:38 AM
  4. What size screw
    By guelch27 in forum SRAM
    Last Post: 03-05-2007, 06:59 AM
  5. What size screw?
    By SLC Road Biker in forum Components, Wrenching
    Last Post: 02-06-2007, 06:17 AM
