Using modern Derailleurs w/friction shifters?
Results 1 to 8 of 8
    Oct 2004
    Can I use a modern indexing style derailleur with a traditional bike that has downtube friction shifters? I know that the indexing is done in the brifters, not the derailleur, but are there any other problems retrofitting say, a new Campy rear derailleur on a bike with a five or six speed freewheel, and using the original downtube friction shifters?
    Phototone
    LC
    LC is offline
    Friction shifters can do anything.
    Feb 2002
    Should work, but
    The challenge may be that the gears are quite close together and your "hand dexterity" could be the limit in getting quick shifts. If you remember the old shifting technique, you would overshift slightly and then drop back in order to get a quick shift and then line up the derailleur. This procedure could result in overshifts with 10s. Also, since the cogs are closer together, your ability to align the derailleur might be an issue. All that said, I have seen one report of someone doing this and saying that their shifting skills were up to the task. Given that some people never seemed to master 5 speed non-index shifting, YMMV.
    With time it just feels normal.
    I found that, at least with bar-ends in friction mode, I got the feel of shifting a 9 speed pretty quickly. I missed once in a while like I did with a 5 speed, but not that often. Adjustment was not an issue at all.
    We have nothing to lube but our chains.
    Oct 2004
    I want to shift 5 and 6 speed freewheels.
    Quote Originally Posted by Kerry Irons
    I won't be shifting 9 and 10 speed cassettes, but rather 5 or 6 speed freewheels. The question was whether current higher quality derailleurs would work OK on older bikes as replacements for broken or worn-out derailleurs. I will not be changing out the rear hub for a 9 or 10 speed cassette.
    Phototone
    Simple answer
    Quote Originally Posted by phototone
    Phototone
    Yes. But if you like older stuff there is plenty of it on ebay.Alot of it can be pretty cheap.
    Reputation: PdxMark's Avatar
    Quote Originally Posted by Rusty Coggs
    Will a 5-6 speed chain fit through a 10sp derailleur cage?
    toomanybikes
    Guest
    Probably - but you are going it difficult to buy a chain these days made for less than 8 speed.
    I find that chain works just fine on a 6 speed freewheel with a Veloce 9 spd rear derailleur. So you should be fine.
  1. Bar end friction shifters with Campagnolo 10 sp
    By buffedupboy in forum Components, Wrenching
    Last Post: 10-18-2004, 06:40 PM
  2. Parts for D/A shifters
    By Dctrofspin in forum Components, Wrenching
    Last Post: 09-28-2004, 08:59 AM
  3. Mt. Bike derailleurs and road shifters
    By CU155 in forum Components, Wrenching
    Last Post: 07-16-2004, 03:46 PM
  4. Sora 8 speed shifters with ultegra der. chain and 8speed cassette
    By mxtater9 in forum Components, Wrenching
    Last Post: 06-20-2004, 07:27 AM
  5. Cowhorn bars & shifters
    By FlippingHades in forum Commuting, Touring and Ride Reports
    Last Post: 05-19-2004, 11:31 AM
