Veloce - What Bottom Bracket
Results 1 to 4 of 4
    May 2004
    Hello All
    I've Just become a member, so treat me gently.
    I have a full veloce 9 speed (tripple) setup on my Coppi (English BB), and I have just bought a reasonable titanium frame (Italian BB).
    I would like to upgrade the bottom bracket to Chorus or if necessary Record.
    I have been told that it is it a straight swap, but I have also been told they will not fit.
    Help Please.
    Best Wishes to All
    Nick
    hi, I'm Larry
    Reputation: bimini's Avatar
    Jul 2003
    Here is a link to Branford bike
    http://www.branfordbike.com/bottombr/bb.html
    Veloce cranks cannot be used with a chorus or Record BB. It will change the chainline and may even interfere with rear stays.
    You must use the Cartridge style AC-H 115 mm (i think) BB with the Veloce triple.
    If you want to Chorus or Record you can get a 111mm Chorus or Record BB and then a Chorus or Record triple crank. (expensive!)
    Branford has answers to all your questions.
    Quote Originally Posted by Nick
    Hello All
    Help Please.
    Best Wishes to All
    Nick
    Oct 2002
    Consider Phil Wood
    As Bimini mentioned a Chorus/Record bottom bracket will not work. If you're not planning on upgrading the drivetrain anytime soon, I would consider a Phil Wood bottom bracket. It is worth while upgrade of the Veloce/Centaur bottom bracket.
    May 2004
    Thanks
    Thanks for the replys, I now know what I am looking for
    Regards
    Nick
  1. looking for Bottom bracket spacers
    By mdevos in forum Components, Wrenching
    Last Post: 04-21-2004, 08:15 AM
  2. Creaky bottom bracket? Loctite? Plumbers tape?
    By mtbcyclist in forum Components, Wrenching
    Last Post: 04-21-2004, 05:22 AM
  3. Replies: 1
    Last Post: 04-15-2004, 08:11 AM
  4. Fitting FSA ti bottom bracket - problems?
    By Gilo in forum Components, Wrenching
    Last Post: 04-06-2004, 07:26 PM
  5. Big bottom bracket problem...
    By rocklax in forum Components, Wrenching
    Last Post: 03-19-2004, 11:36 AM
