Video Cameras for Bike
Results 1 to 11 of 11
    Sep 2018
    Does anyone here use video cameras for recording rides? I live out in the sticks and the only place to ride is along a state highway. Super hilly and looks like a fun route, but I want to be able to record what's ahead of me and behind me as I ride just in case there's even an accident. Ideally video would send to the cloud vs staying on the device.
    Curious if anyone uses video cameras and what recommendations might be. Thanks in advance for helpful replies.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    You better have some data plan if you're thinking of sending live video good enough to read license plates to the cloud for whole rides. To my knowledge nothing like that exists.
    I used to use two GoPro cameras on K-edge mounts for front and rear video. I had battery extenders that allowed me to record over 4 hours of video. Nothing happened for years so I stopped using them. The one time I did witness a car accident the camera had conveniently run out of battery.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by mml373 View Post
    What kind of bandwidth are you going to get 'out in the sticks'... if you get any service at all.
    What cloud service are you gonna use that you can stream and save several hours of HD video?
    What data plan will you use to give you enough data? My Gopro at 1080 takes about 300MB for one minute of video. That's 18GB per hour!
    Even 'Unlimited Plans' are truly unlimited. After you reach a data limit, they will throttle back your speeds. For instance, Verizon Unlimited give you 22GB of full speed, then they'll throttle you. That'd be a little over 1hr. After that your upload speeds would be useless.
    Oct 2013
    I run forward & rearward camera's. Cyclic Fly 6 & 12. The batteries last about 3.5 hours, and it records to a micro sd card. Recording overwrites previous recordings, a 64g card will keep about 3 hours of video before overwriting. The 6 is kinda picky on the exact card you can use.
    I had to return the rear due to warrenty issue, but finally got it resolved and it seems to be working ok now.
    Good: Videos are HD quality, sound is good, stablity excellent.
    Not so Good: Multifunction cameras where everything is done through one button are very difficult to operate. When your out on the road, without the instructions, road noise, people talking, and no indicator lights, it's just a crap shoot what functions are on. Sometimes it records with the lights off which is really confusing.
    I prefer the 12, but it is heavy. If I was getting another set, I'd get 2 "12's", put a red lense on the one for the rear.
    BANNED
    Sep 2018
    Appreciate all the inputs. Sounds like cloud upload is really not happening and Micro SD is as good as I can hope for, realistically. Duriel, I'll have a look at a similar setup to what you've mentioned. I don't need more than a few minutes' of storage, really, just enough to capture an incident if one happens.
    Oct 2013
    They record automatically and save in case of a high acceleration accident. Use can always use smaller cards. If you have an incident, I have an extra card I put in so I can look at what happened laters.
    Most confrontations are not accidents. Close calls can be delivered to the police and prosecuted if you have the support.
    After you get your setup, post back on your decision & review.
    I've actually found the close calls and phoned them, let them know I know who they are! ... and where they hang. Since they already gave up playing fair, I let them know they'll never see anything coming.
    BANNED
    Sep 2018
    The looping sounds like it'll address my main concern- having footage of an accident or harassment (less of a concern.) I plan to get a 6 for the rear of the bike (older ones are affordable) and a 12 for the front.
    Sep 2014
    Like duriel, I run the Cycliq Fly12ce front and Fly6ce on the rear. I get about 4 hours of recording most times. I do not use the light function on the front to eek out as much recording time as possible. I use a separate light for visibility. With a 64gb sd card, I'm getting about 5.5 hrs recording time before looping. File sizes are averaging 2gb per 10min. The Fly6 also has a 64gb card and file sizes are avg 1.5gb per 10min. So I should be getting more recording time than the front before looping.
    I wouldn't want to ride without them. But I'm not under any impression that in the US with our small colored plates, that I'm going to capture a plate number unless I'm really close to the car - even at high quality settings. It's just not going to happen. It doesn't mean they are useless, just don't expect to be able to capture the plate of that car that buzzed you or cut you off unless you get really close. As a black box of sort it's great and can at least give some evidence in case of an accident. Recently where I live, another rider with Cycliq cameras, was successful in getting a driver prosecuted. He drove through the middle of a group of cyclists who were stopped at a stop sign waiting on traffic to turn. So they definitely are worth it IMO.
    If you are going to mount the Fly12 to your bars, definitely get a alloy mount for it. It's a fairly heavy piece and can brake flimsy plastic mounts. I use a K-edge out front Garmin/go-pro combo mount that is great. It puts the camera center just below the bar level and my computer on top.
    Reputation: burgrat's Avatar
    Nov 2005
    I really wish there were more manufacturers in the game to give Cycliq some competition. The reviews are mixed on the quality and reliability of Cycliq, so I've been hesitant to get one (or 2). I wish Wahoo, Garmin, or GoPro would make bike-specific cameras (i.e. small and aero).
    Oct 2013
    There are a couple others you could look at.. I have both but mostly use them for the moto. They don't have lights.
    Tachyon XC Micro
    Panasonic HX-A100
    I like both, the panasonic you can put on your helmet and it sees where you look.
    The Tachyon suffers similar problems as the Cyclic, since once it's on your helmet, you cannot tell when it is on, same as the one button cyclic.
    The panasonic has a arm band with the control, and a 'on' light, I like it a lot better, easy on/off/verification of status.
    But they are not made for bikes, but have mounts you could adapt.
    The cyclic mounts work fine. All of these are HD or near HD quality, if you they are in the lane next to you, you can see the plate & identify the # usually, but **** happens.
    Using a recording device works, trucks that I thought were Toyota's were correctly identified as Chevy's, etc, etc. You would be surprized at the # of a**hole drivers that are running co names on the side with phone numbers! Easy Peasy! When you call in and ask for the co owner, it can get right to the point.
    BANNED
    May 2011
    Quote Originally Posted by burgrat View Post
    Yeah, I've had very mixed experience with Cycliq cameras. My original FLY12CE was a brick out of the box and when I finally got a working one, decided it was just too heavy (actually worried about damaging my bars from either the mount slipping from the weight or having to tighten the mount too much to avoid slipping). Really with someone would make a front camera-only device. There are plenty of light, bright, long-lasting front lights in the market. My wife and I both use the Fly6CE for the rear. Kind of fiddly to get working (very picking about SD cards and only 32GB or less) and a few out-of-box bricks but once you get them working, they're pretty solid. There's a HUGE multi-year thread on DCRainmaker's site about Cycliq you might want to check out.
    Well, you know, that's just, like, your opinion man. - The Dude
  1. Bike Cameras. Recommendations?
    By JapanDave in forum General Cycling Discussion
    Last Post: 05-02-2012, 06:46 PM
  2. IP video cameras anyone?
    By innergel in forum The Lounge
    Last Post: 11-01-2011, 05:31 AM
  3. Video Cameras
    By thebikingcello in forum The Lounge
    Last Post: 04-21-2011, 08:56 AM
  4. Video cameras for the commute
    By WEG in forum Commuting, Touring and Ride Reports
    Last Post: 10-16-2010, 09:14 PM
  5. DIY: bike mounted tripod for small digital cameras
    By meat tooth paste in forum Commuting, Touring and Ride Reports
    Last Post: 02-19-2005, 02:19 PM
