Vintage Look Pedal Failure
Results 1 to 6 of 6
    Sep 2018
    I have a vintage bike I picked up awhile back that came with Look PP156 pedals (beautiful, back in tha day.) Was riding the trainer a few weeks ago and the right pedal suddenly came loose while I was in the middle of a jump. Glad I was on the trainer when this happened and not in the road. There is a reason I was on the trainer for the first ride with this old bike... :-)
    Looks like the nut that holds the spindle to the pedal was loose. Unfortunately I do not have the appropriate sized box wrench to tighten the pedal, but I am going to do so as soon as I can get ahold of a wrench. Question I have is whether others have experienced this kind of issue with these old Look pedals and if tightening the spindle nut will fix the problem. I cannot see any damage to the threads or other issues...but I'm not going to go put full power into the pedals (even after I fix them) till I know there's not a bigger issue at play. Thanks in advance for helpful replies.
    'brifter' is a lame word.
    Pedal body is aluminum...axle nut is plastic (you need a 19mm box wrench btw)...they come loose, and make noise. Take the pedal apart, clean/grease the internals and then grease the threads on the nut. Tighten them back up and keep an eye on them. One is left hand threads...the right pedal I think?
    I work for some bike racers
    and a bunch of skateboards
    Russian Troll Farmer
    Sep 2016
    I have quite a collection of classic Look pedals, and I've never had this happen. I would assume the problem was one of the previous owner being a lousy mechanic.
    "L'enfer, c'est les autres"
    Sep 2018
    Thanks, all. I'll find the right size wrench and clean/grease/etc...simple stuff. :-)
    Appreciate your help.
    Banned forever.....or not
    Aug 2002
    I still have a PP76 on one of my bikes. I still have a Look/Ultegra, and a Look/105 set in my parts bin.
    Dogbert.
    I>U
    a real member's member
    Jul 2016
    pro buyer's tip: check your local craigslist for bikes with Look pedals. chances are good the seller will part 'em out, especially if you bring him decent platform replacements in exchange.
  1. Replies: 8
    Last Post: 06-16-2015, 06:44 PM
  2. Trek not liable for failure to warn of carbon fiber failure
    By RichardT in forum General Cycling Discussion
    Last Post: 03-21-2015, 05:56 PM
  3. Replies: 0
    Last Post: 03-07-2011, 05:24 PM
  4. Frackin Hard Drives. . .Failure on Failure
    By Ridgetop in forum The Lounge
    Last Post: 05-21-2010, 09:46 AM
  5. Look Keo Carbon Ti Failure
    By curvilinear in forum Components, Wrenching
    Last Post: 12-06-2007, 03:51 AM
