What to Do With Used Chains?
Results 1 to 25 of 30
    Nov 2013
    I'm starting to get quite a pile of used chains and have no idea what to do with them. What do you do with your used bicycle chains?
    While I've seen a lot of creative people turn their chains into art, I'm afraid I don't really have the desire (or talent) to do that
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    'brifter' is a lame word.
    Uhhmmm...throw them away?
    I work for some bike racers
    and a bunch of skateboards
    Nov 2013
    I guess that's an option, but they're hardly biodegradable and I prefer to be a bit more environmentally conscious than that. My local municipality does recycle metal, so I suppose I could take them there.
    Aug 2017
    The clock is an excellent idea. My LBS made little wreaths ornaments from them and handed them out around the holidays. They used some brake/shifter cable for the hanger and some side plates to make a bow.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by PoorInRichfield View Post
    Take them to metal recycling. Even if your city doesn't--there are private metal recyclers that will pay for metal. Granted you;re only looking at 1/4lb of steel.
    Nov 2013
    I'm assuming most of the crafty recycling solutions would require a bit of welding to keep the chain's shape, such as the clock idea? If there was a cheaper/easier alternative to welding, like perhaps soldering, I guess I could try my skills at crafting and selling my chain creations on eBay My crafts should go for top-dollar 'cause a lot of my chains are ultra-light KMC chains!
    Jan 2005
    Amigo. What are you talking about?
    This is the PERFECT excuse to tell Wifey why you "need" a stick welder. PERFECT. You might even be able to justify a plasma cutter out of it too.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    You need tig for welding chains. I used to have a company called Bicyclart, made all sorts of stuff out of chains, clocks, lamps, sculpture, you name it. Did art fairs, that sort of thing.
    I looked at every possible fusing method to not have to tig each and every link together...there were no other good ones.
    Cleaning thousands of links of chain in order to prepare it for welding was a huge chore...
    Oct 2013
    Burn them!!!
    BANNED
    Feb 2005
    I have done that, leads to toxic fumes.
    Jan 2005
    Quote Originally Posted by rideit View Post
    Didn't have an ultrasonic bath?
    Nov 2015
    Just over-tighten/lightly smash the plates with a chain tool or pliers. Cleaner and easier.
    I used to have a fold-down work surface that was held up by old cables. I'm sure you could use chains instead.
    Feb 2005
    Quote Originally Posted by Pisgah2000 View Post
    It just doesn't work. I even contacted a hydraulic press manufaturer to make something, you don't get consistent enough results to do more than one item like that before you get frustrated. l really wanted that method to work.
    Feb 2005
    There would still be traces of grease on them, which contaminates the welds. It was most important with house numbers that I used to make in order for them to keep their shape...
    Oct 2017
    JB Weld?
    Feb 2005
    Didn't work well for my applications.
    What the what???
    Jul 2009
    I made key fobs with a few extra links...
    The Law of Headwinds states: If the ride out is easy you better leave something in the tank for the turn...
    Jun 2013
    Speaking of chains, i'll hide my post here.
    Bought an 11 speed bike, cut the chain too short (Ultegra 11 speed) because the new R8000 stuff is a PIA to set chain length.
    First forum member to PM me with a funny knock knock joke gets the chain.
    I'll send it in a padded envelope, free. Seriously.
    Feb 2005
    (a few examples)
    Nov 2013
    Quote Originally Posted by Peter Lauridsen View Post
    Measure twice, cut once Do you follow the method of putting the chain on the large chain-ring and large cog, then add two links? That method has worked for me.
    I can feel your pain, though. I have a barely used KMC X11SL chain that is now too short because I put a larger cassette on the bike after a few hundred miles.
    (a few examples)
    Nice work, rideit! I like the retro chain-lines even though I've been allergic to chain guards since I was a kid. When ever I got a new BMX bike, the first thing I did was remove the chain guard and reflectors
    If you'd sized it small/small you would have been fine w/ the larger cassette...as long as everything was within spec.
    Oct 2013
    Maybe you can see some ideas from these folks at bicycletrash.com
    My son gave me one of their 14t bottle openers as a gift, it works incredibly well.
    Oct 2013
    more ideas - they make belts and bags from used innertubes
    Reputation: mtrac's Avatar
    Sep 2013
  1. Why can unidirectional chains only be used on doubles?
    By matchmaker in forum Components, Wrenching
    Last Post: 01-11-2012, 12:31 PM
  2. Replies: 4
    Last Post: 06-30-2004, 04:55 PM
  3. Chains
    By stevenf in forum Fixed/Single Speed
    Last Post: 04-25-2004, 06:05 AM
  4. 10 Speed Chains. Where was that thread?
    By Boyd in forum General Cycling Discussion
    Last Post: 04-22-2004, 04:15 PM
  5. Purchasing Chains in bulk...
    By DMtbRider in forum Components, Wrenching
    Last Post: 03-03-2004, 12:15 PM
