What grease do you use in your speedplays
Results 1 to 4 of 4
    Get me to In&Out
    Reputation: spookyload's Avatar
    I am at 8000 miles on my current speedplays. They need a little grease, so I bought the injector by Manitou. What grease do you guys use with it for speedplays? I didn't get the speedplay version that is prepacked with grease, so I am fishing around. Would the Manitou grease that came with the gun be OK? I also have a tube of Philwood green grease that fits the adapter. I am leaning that way personally.
    Cyclists really need to learn a little Rule #5.
    May 2002
    The Speedplay stuff is CRC Sta-Lube Marine Grease. It's something like $6 for 3 30oz cartridges. They fit in one of those industry standard $8.99 grease guns that Speedplay sells for $20 bucks or something....
    Cipo's long lost cousin
    Reputation: Steve-O's Avatar
    Fwiw
    I have a set of Frogs with about 5k miles and I've been using the Manitou PrepM grease on them. This grease is probably a little light for the application (certainly not as viscous as marine grease or Phils) but it seems to work. I figure some grease is better then no grease... I give them a couple of shots every 1k to 1.5k miles....
    "Cycling is like a church - many attend, but few understand." -- Jim Burlant
    Mar 2002
    I use whatever marine grease I find at the hardware store.
    If you don't want to spend that much on a stupid little grease gun most craft stores sell plastic syringes (mine is called the "pretty petal pumper") that work just as well for speedplay pedals and only cost a couple bucks.
  1. foot pain and speedplays
    By CU155 in forum General Cycling Discussion
    Last Post: 07-14-2004, 05:30 PM
  2. bearing grease recommendations?
    By fiddledoc in forum Components, Wrenching
    Last Post: 07-09-2004, 04:34 PM
  3. To grease or not to grease...
    By team_sheepshead in forum General Cycling Discussion
    Last Post: 05-20-2004, 09:10 AM
  4. Grease to use in X-2's
    By ringroadwarrior in forum Components, Wrenching
    Last Post: 05-14-2004, 01:35 AM
  5. Le Tour Whisper White Bearing Grease
    By Bonked in forum Components, Wrenching
    Last Post: 03-04-2004, 11:39 AM
