What to Lubricant the wheel bears with?
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 82
    Mar 2019
    What to Lubricant the wheel bearings with?
    I lube my wheel bearing with wd40 every other week. What do you use to lubricant yours?
    'brifter' is f'ing stupid
    Quote Originally Posted by s10aromeo View Post
    You're kidding, right?
    #promechaniclife
    Mar 2019
    No Iím not
    double tap
    #promechaniclife
    What kind of hubs? Spray WD40...blue can? You just spray WD on the hubs or take them apart and actually ruin the grease w/ it?
    #promechaniclife
    Reputation: nova_rider's Avatar
    Sep 2005
    Are you using conventional, cartridge, or ceramic wheel bearings? WD40 might be fine for ceramic and cartridge and for cleaning, but conventional cup and cone bearings need grease if you want them to last.
    Nothing every other never.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    WD40 has zero place on a bike, unless you are degreasing an older Shimano shifter.
    I don't lube my wheels.
    With cup/cone bearings, I service the hubs once a year. Clean out old grease, clean and inspect bearings/races. Repack with Park Ploylube 1000 or other high temp/waterproof grease.
    With cartridge bearings, replace when they start grinding.
    Again, WD40, has ZERO place on a bike.
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Reputation: Oxtox's Avatar
    Aug 2006
    Quote Originally Posted by frdfandc View Post
    WD40 has zero place on a bike...
    would normally agree with that, but recently found a weird blue glob that had attached itself to the inside of the fork. tried a few things (Goo Gone, etc) to remove it, but a spray of WD took it off.
    but, yeah...'lubing' wheel bearings with it is srsly off-the-mark.
    Rub it............
    Nov 2007
    Quote Originally Posted by Oxtox View Post
    OK, exception made. It is good for removing stubborn glue like substances.
    Sep 2005
    I use WD40 extensively after every drivetrain wash. Dry with a leaf blower, then WD40 everything to remove any residual moisture, let it sit overnight, then finish with light oil based lube. Great stuff.
    Nov 2014
    I use WD40 to clean my disc rotors, great stuff. I'm faster than ever
    Reputation: velodog's Avatar
    Sep 2007
    Grease, once a year.
    Too old to ride plastic
    Sep 2007
    Quote Originally Posted by nova_rider View Post
    I run my chain thru rag damp with WD40 to clean it down before lubing.
    Russian Troll Farmer
    Sep 2016
    TROLL ALERT!!!!!!
    Notice it's a person with few posts, then claiming to use WD-40 in a ridiculous way? Look at his other posts; pointless prattle with intentionally horrendous grammar and stereotypical troglodyte spelling errors and implausibly ridiculous ideas. Yes, people, this is a classic troll. Don't feed the troll, and he will go away; it's really that simple!!!
    "L'enfer, c'est les autres"
    Sep 2005
    Bearing service should be based on mileage more so than time.
    Mar 2019
    Thanks for the range of replies. I am going to try grease on my bearings.What brand grease do you recommend?
    Sep 2007
    You're right, but a year has been giving me 3-6000 miles and I'm comfortable with that kind of mileage between lubes.
    I'll ask again...what kind of hubs?
    #promechaniclife
    Reputation: walrus's Avatar
    I just repacked my wheel bearings last night. Cup and cone. I used Phil's waterproof grease, the green stuff. It's the only thing made by Phils I can afford to put on my bike. It would be imposable to use wd-40, The grease holds the bearings in place while you put the axle back in.
    Sep 2007
    Quote Originally Posted by walrus View Post
    That's cause you're doing it wrong. You need to spray the WD40 all over the outside of the hub and it will automatically find it's way past the seals refreshing the old oil on the bearings.
    Not only is this much easier than repacking the bearings, the wheels will spin much faster without all the drag from the stiff grease.
    Reputation: Akirasho's Avatar
    I tried using WD-40 to lube a couple of loose balls. Try explaining that to a doc!
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    TROLL ALERT!!!!!!
    But trolls are so much fun. And when you get tired of them, they taste like chicken.
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Well.... he didn't say what WD40 he uses.
    Sep 2007
    Quote Originally Posted by Akirasho View Post
    I once knew and worked with a fellow that rubbed WD40 into his arthritic knees to ease the pain. He didn't need no stinkin' Doctor.
  1. Best bears, worst bears.
    By QuiQuaeQuod in forum The Lounge
    Last Post: 05-18-2006, 11:44 AM
  2. O-Ring Lubricant?
    By Carbonman in forum Components, Wrenching
    Last Post: 02-19-2006, 08:33 PM
  3. New Member with Chain lubricant ?
    By AnotherRedRyder in forum Beginner's Corner
    Last Post: 09-27-2005, 06:02 AM
  4. New Member with Chain lubricant ?
    By AnotherRedRyder in forum General Cycling Discussion
    Last Post: 09-22-2005, 06:04 PM
  5. Ksyrium freehub lubricant
    By martroy in forum Components, Wrenching
    Last Post: 07-28-2004, 05:52 AM
