Wheel spacing advice needed
Results 1 to 6 of 6
    cs1
    cs1 is offline
    Reputation: cs1's Avatar
    Sep 2003
    Does anyone know if you can change a Shimano road hub to 135mm spacing. Iím looking for a factory built wheel with 135mm for a rim brake frame. A few years ago they were everywhere. Now not so much. 105 and Ultegra are reasonably priced buy I am not sure if they can be modified.
    1995 Waterford 1200
    1999 Waterford RSE-11
    Plus a host of old bikes too many to list.
    'brifter' is a lame word.
    All you have to do is find an axle that's 5mm longer, add a 5mm spacer to the non-drive side, and recenter the rim.
    I work for some bike racers
    and a bunch of skateboards
    cs1
    cs1 is offline
    Sep 2003
    Are you able to do that with the current 11 speed hubs? Iíve done it many times on earlier versions. But I donít have any of the new ones to see. It has to have cup and cone bearings in order to swap axles.
    1995 Waterford 1200
    Yes, that's why I posted what I did. It's possible if you can find the correct axle.
    cs1
    cs1 is offline
    Sep 2003
    Thanks.
    1995 Waterford 1200
    Banned forever.....or not
    Aug 2002
    11 Speed 105 hubs (FH-5800) still use straight threaded axles, so you should be able to find a 135mm straight threaded axel to replace it. (you should also be able to buy 1mm spacers to add on the axel (10mm I think) (a good bike shop should carry them)
    Ultegra and Dura Ace 11 speed uses a difference type of axel.
    https://si.shimano.com/pdfs/ev/EV-FH-5800-3719A.pdf
    Dogbert.
    I>U
  1. Help needed with headset spacing on Carbon stem.
    By chas0039 in forum Motobecane - Mercier
    Last Post: 04-06-2010, 05:00 PM
  2. Rear hub spacing advice
    By superjohnny in forum Fixed/Single Speed
    Last Post: 06-18-2007, 06:57 PM
  3. 130mm rear wheel spacing- What hubs/cogs?
    By Sablotny in forum Components, Wrenching
    Last Post: 08-30-2005, 01:15 PM
  4. Rear Wheel Spacing? 130mm in a 126 frame
    By cdadaa in forum Components, Wrenching
    Last Post: 05-19-2004, 02:13 PM
  5. Rear Wheel Spacing? A 130mm in a 126 frame??
    Last Post: 05-18-2004, 06:54 PM
