Who makes the lightest 53/39 crankset out there?
Results 1 to 8 of 8
    Jul 2013
    My understanding is that itís not the Shimano Dura-Ace 9100, nor is it the Campy Record.
    Whatís the lightest 53/39 crankset?
    And if the lightest isnít sold as a crankset, then who makes the lightest cranks?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    https://us.thm.bike/en/cranksets/cla.../7-size-170_mm
    https://www.fibre-lyte.co.uk/fl/fl_c...ring_2011.html
    A bit under 400 grams...questionable ring durability, and only a mere $1,500.
    Do note the maximum rider+bike+stuff system weight of 120kg.
    Reputation: Srode's Avatar
    Aug 2012
    Cannondale SiSL2 in a 53/39 is 445 grams from what I've read, you can probably get one around $500 used, or around $1200 new.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Shimano, Sram, Campy, none of them are particularly light. The Cannondale SISL2 I believe is the lightest of the OEM production type cranks.
    To go lighter you gotta go to boutique mfg's in all carbon. I believe THM is the lightest.
    This test compares weights, costs, and stiffness.
    Road Bike Crank Test - Fairwheel Bikes Blog
    'brifter' is a lame word.
    What kind of bb compatibility do you need?
    I work for some bike racers
    and a bunch of skateboards
    Jul 2013
    Excellent point!
    PF30.
    There are some light ones but most are pretty spendy. The SRAM is only a couple ounces heavier and a LOT less expensive. I'd probably go that route and then maybe save an ounce or 2 on lighter chainrings maybe.
    Oct 2011
    THM and Lightning are in the group of lightest. Google them. Plenty of info there.
    Be mindful of the rider weight limits as you get into that territory.
    Makes me wonder how they feel sprinting or if you should even do that with them. One of those tool for the job kind of things I guess.
    Being a bigger guy I never have ridden the uber light stuff so I would be intetested to hear from others how the stiffness of these super light cranks actually feel compared to say Record or DA.
    Good Luck
  1. Lightest clincher out there
    By mdutcher in forum Wheels and Tires
    Last Post: 03-04-2012, 10:31 AM
  2. There's no over component comparison chart out there, is there?
    By Ventruck in forum Components, Wrenching
    Last Post: 07-23-2009, 09:55 PM
  3. who makes lightest 50/34 chainrings
    By Tissot in forum Components, Wrenching
    Last Post: 06-02-2009, 09:16 PM
  4. Who makes the lightest wide-side -wall alloy wheels?
    By BATMAN in forum Wheels and Tires
    Last Post: 10-18-2005, 01:38 PM
  5. Lightest 10spd Carbon crankset
    By SANDICO in forum Components, Wrenching
    Last Post: 09-26-2005, 02:41 PM
